Old 07-20-2016, 09:26 PM   #1
trailer brakes
Will trailer brakes work if I don't have trans in tow/haul mode?Truck is 2015 GMC sierra.
2016 Hyper Lite XLR 30HDS
2015 GMC Sierra Denali 3500 DRW
GMCdiesel is offline   Reply With Quote
Old 07-20-2016, 09:36 PM   #2
Who Dares, Wins
doc73's Avatar
Yes. They work when plugged into truck. Trans mode just changes some internal settings of shifting stuff. Your brakes are controlled by the brake controller. For me built in, if after market mine were always wired to the brake light wire / switch on the pedal.
Have a 15 Chevy HD
Sent from my Samsung Galaxy S7
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 07-21-2016, 07:44 AM   #3
f5moab's Avatar
Also tow-haul mode will signal the TV's computer to increase voltage to help charge (keep charged) the trailer's battery(ies).
f5moab is offline   Reply With Quote
Old 07-21-2016, 08:00 AM   #4
dcheatwood's Avatar
Interesting. Did not know that. Thanks.
2018 Forester 3011 DS
dcheatwood is online now   Reply With Quote
Old 07-21-2016, 08:47 AM   #5
f5moab's Avatar
From a 2015 Silverado owner's manual (GMC would be the same, just a different name); page 9-93
If charging a remote (non-vehicle)
battery, press the Tow/Haul Mode
button, if equipped, at the end of the
shift lever. This will boost the
vehicle system voltage and properly
charge the battery. If the trailer is
too light for Tow/Haul Mode, or the
vehicle is not equipped with Tow/
Haul, turn on the headlamps as a
second way to boost the vehicle
system and charge the battery.
Since I tow a 3200 lb popup, I do not use tow/haul mode, but I do run with the headlamps on. Not just to charge the battery, but to light up all the lights on the trail.
Toyota might do the same????
Old 07-21-2016, 05:36 PM   #6
dcheatwood's Avatar
I'll have to check that out. 😱
Old 07-21-2016, 05:54 PM   #7
Also changes your turn signals from 3 flashes to 6 flashes if you just touch the stalk.
2011 Traverse LT, 3.6L, FWD
Old 07-21-2016, 07:05 PM   #8
Mine will charge the battery without using tow haul mode
Big Red and 30WR is offline   Reply With Quote
Old 07-21-2016, 07:16 PM   #9
Hugeez's Avatar
X2
2018 PUMA 31 BHSS
2017 RAM 2500 LARAMIE 6.4 HEMI 4X4
E2 WDH
Troy, Josie and our 2 K9 co-pilots Breck and Maggie
USN 86-92
9 nights camped so far in 2018
Hugeez is offline   Reply With Quote
Old 07-21-2016, 08:03 PM   #10
Thanks,I did not know that.
I do have utility trailer and it only weight 1,500 lb empty.
brakes, trailer
