Old 06-29-2016, 03:33 PM   #1
Trailer Brakes Disconnecting Intermittently
I have a 2014 Ram 2500 pulling a 31' travel trailer. After about 3 weeks on the road, I get the message to check the wiring & trailer is disconnected. The strange thing is that it only happens after coming to a complete stop (exiting highway for gas). Once I pull back on the highway the brakes reconnect and I can drive (with brakes) until the next step. I've checked the plug, ground at the end of trailer plug along with checking for loose connections at each brake. Any thoughts?
sellis1053 is offline   Reply With Quote
Old 07-02-2016, 09:03 PM   #2
My 2016 Chevy 2500 does that. Seems my TT umbilical is a bit lose in the socket. I tied a length of 550 cord to it and tie it off on the truck. I am trying to figure out a less redneck way of dealing with this issue.
2017 Keystone Cougar 28RDB
Buck1032 is offline   Reply With Quote
Old 07-02-2016, 09:51 PM   #3
I have a 2016 GMC 2500 that does the same. I just wrapped black electrical tape around the plug until it fit snug and haven't had an issue since.
fueller is offline   Reply With Quote
Old 07-02-2016, 10:37 PM   #4
My trailer has done this on two different trucks. Turns out it is due to corrosion in the trailer cord. I spray a little Deoxit cleaner in it and let it work it's magic. Good as new.
DeoxIT® D-Series - Contact Cleaner & Rejuvenator
Kf4mnc is offline   Reply With Quote
Old 07-03-2016, 07:18 AM   #5
Replacement cords can be had on Amazon, etc . They come in different lengths also, would take about 15 minutes to change . There are also plug holders that attach to the tongue jack that will keep it dry when not in use
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 07-03-2016, 08:21 AM   #6
Its likely a loose plug, what i found years ago, was the wire running thru the axle had worn and would ground out , causing intermit braking. I havent heard of that happening lately Good luck
Big Bill is offline   Reply With Quote
Old 07-04-2016, 03:50 PM   #7
etothepii's Avatar
I had a Trailblazer a while back that did that. In my case, the INSIDE of the seven pin connector was corroded. I mean I cleaned everything I could see with vinegar, then a store bought product with no success. After taking the connector apart, seeing and cleaning the green gunk, I never had a problem again.
2014 Rockwood 2306
Fastway E2 equalizing hitch
Prodigy P2 brake controller
2011 Ford F150 Ecoboost, Supercab
etothepii is offline   Reply With Quote
Old 07-04-2016, 05:19 PM   #8
I don't think it's the plug. I can wiggle and pull it partially out and can't make it fail. If it's a short somewhere, can anyone explain why it only happens when coming to a complete stop?
Old 07-04-2016, 07:12 PM   #9
Ground connection to cord on trailer? Maybe grounding thru ball instead of cord
Old 07-04-2016, 09:22 PM   #10
Check the electrical box where the camper plug runs to and ensure that there aren't any loose wire twist connectors.
Skyliner is offline   Reply With Quote
brakes, trailer
