Old 05-05-2016, 09:45 AM   #1
firsthere's Avatar
Trailer Brakes Grabbing on Initial departure.
The brakes on both the TT and the dump trailer are very grabby when initially heading out then back to normal after a couple stops. This is with the controller in the truck at its lowest setting.
It's not a big deal (so far) just curious what causes this. Thanks!
TT- 2016 Grey Wolf 21RB
TV- 2004 GMC3500 4x
firsthere is offline   Reply With Quote
Old 05-05-2016, 10:00 AM   #2
jeff64's Avatar
Oxidation(rust) on the machined cast iron from humidity in the air. Changes friction between smooth machined metal and pads
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-05-2016, 10:16 AM   #3
Head Rambler
I always lightly apply the brakes with the manual lever going down the driveway for a little bit when I'm leaving out after it sits a while. That lets me know that the brakes are working, scrubs any rust off, and warms them up a little.
Gotta go campin!
Old 05-05-2016, 10:22 AM   #4
firsthere's Avatar
Yes it tends to get a bit humid here in Oregon.
TV- 2004 GMC3500 4x
Old 05-05-2016, 11:10 AM   #5
Head Rambler
It tends to get a little humid here in South Alabama also! fancy that, opposite corners have the same problems!
Gotta go campin!
Old 05-05-2016, 11:36 AM   #6
MacDR's Avatar
Still Cold here in Wisconsin.. �� But I always manually hit the brakes a couple of time to knock off the oxidation and as a reminder I actually plugged in my 7pin .. Yes I forgot once.. Had to stop a mile down the road..
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Day's Camped 2018 "32"
You can find us: CrockeryCreek RV Park, MI 9/29 - 10/1
MacDR is offline   Reply With Quote
Old 05-05-2016, 11:56 AM   #7
firsthere's Avatar
So far I have only forgotten to put the steps up once. We get a second chance to check things out after our long gravel driveway to hookup the WD bars and pick the rocks out of the tires.
TV- 2004 GMC3500 4x
Old 05-05-2016, 12:05 PM   #8
RVPP's Avatar
TT brakes grabbing
Had similar problem last winter. Thought it was moisture at first, not. In my case it was the brake controller, after market, that went south.
Good luck, Paul
RVPP is offline   Reply With Quote
Old 05-05-2016, 12:07 PM   #9
Yep - They do that after sitting awhile and rust forms. Once you use them a couple times, they will be back to normal.
Dan & Dawn
South Bend, IN
2014 Lacrosse 327RES
U.P. North is offline   Reply With Quote
brakes, trailer
