Old 09-24-2016, 08:12 AM   #11
peterbilt's Avatar
not good on tires
peterbilt is offline   Reply With Quote
Old 09-24-2016, 09:17 AM   #12
Making a U-turn. The trailer shouldn't hit the truck
Shortline is offline   Reply With Quote
Old 09-24-2016, 10:38 AM   #13
bareftn's Avatar
It all depends on the turning radius of truck and the length of the trailer I bet most would hit. Take your unit into a mall parking lot and cut it all the way and let me know. As for me I know if I tried that on mine it just may and the stress on the trailer and ties would be great and on my semi the sleeper would hit please you take the chance of twisting the trailer and dragging the ties and getting flat spots
bareftn is offline   Reply With Quote
Old 09-24-2016, 10:38 AM   #14
bareftn's Avatar
Originally Posted by peterbilt View Post
not good on tires
X2
Old 09-24-2016, 10:57 AM   #15
Simple solution...make wider turns eh?
otisite2016 is offline   Reply With Quote
Old 09-24-2016, 02:28 PM   #16
Dodge Guy's Avatar
I would love it if I could make a 180 deg. turn! As it is I'm limited to about 85deg.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 09-24-2016, 05:37 PM   #17
Wider turns,really
Old 09-24-2016, 05:55 PM   #18
tkmi's Avatar
I have a 2016 WRL work and play.the front nose cap that covers the propane tanks and Generator.The tow vehicle is a 2002 Ford F350 pickup.when I try to make a hundred eighty degree U-turn, when I get past 90 degrees, and in the second half of the u-turn, the truck and trailer hit causing dents in my rear fender. The tabs that are used to lock down the front black plastic enclosure's put's dent's above and below the tail lights. As anyone else have dents in the back of their truck and not know how or where they came from, now you know.
Don't make u turns, and when you do, look first, if the area is to small to make your turn at 60 deg. In a big circle then go somewhere else.
2013 Silverback 33RL
2010 2500 RAM 6.7L
tkmi is offline   Reply With Quote
trailer, truck
