Old 05-22-2012, 07:56 PM   #11
Originally Posted by poohbearntigger2 View Post
I don't know if you call this better or worse. Now all the lights work BUT the brakes are on all the time. The tires won'r move because the brake is on. When we unplug the trailer wire from the truck, the brakes are off. UGH...I think we may need to have it looked at....So frustrating....
Check that the emergency brake plug is in all the way. It should have a cable hooked to it going back to the tongue on the trailer. If it is missing or not fully seated the brakes will be on all the time.
Old 05-22-2012, 08:06 PM   #12
Fire Instructor's Avatar
Had similar lighting issues with my old utility trailer. It all traced back to a bad ground, which, when repaired, solved the problems.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 06-18-2012, 10:57 PM   #13
Kind of had a similar issue with mine. All lights were working,but no brakes and the controller said there was a short. I looked in the junction box at the hitch where the trailer plug cord is marette tied to the rest of the wiring. I fooled around with those and it was better for a little while then back to the same. I'm taking them all apart now and using dielectric grease. I hope this is the problem.
saskrick is offline   Reply With Quote
brakes
