Forest River Forums
Sunline User Photos
Go Back   Forest River Forums > Forest River Tech Talk > Towing, Hitches & Toads
Old 08-05-2011, 01:26 PM   #1
Trailer is heavier than Tow vehicle - What are the consequences?
This may seem like a dumb question but...
A coworker asked me what would happen if the trailer is heavier than the tow vehicle. In this case, the tow vehicle is rated to tow at 2,000lbs and the trailer is 2,500lbs. He's thinking about renting a travel trailer for the weekend. Is it just more work for the tow vehicle or are there some serious safety issues involved?
I've seen some articles about this but none of them ever said anything about the possible consequences of towing a heavier trailer.
Thanks,
vinman72 is offline   Reply With Quote
Old 08-05-2011, 01:37 PM   #2
RubenZ's Avatar
Thats not uncommon. Many contractors at job sites that pull backhoe's and tractors on goosneck trailers have heavier loads than the truck. Thats where having the proper hitch, brakes, suspension, and tires all come into play.
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
Old 08-05-2011, 01:49 PM   #3
frankm's Avatar
After reading the OP's heading, I would agree with your reply, however once you read the post itself I think this isn't a question about the TT gross weight being greater than the TV's, but instead the trailer's weight exceeding the stated towing capacity of the tow vehicle. This "the tow vehicle is rated to tow at 2,000lbs and the trailer is 2,500lbs" being the key phrase.
If this is the case then the answer would be completely different. If not then I'm confused!
Frank & Rita M
2008 Ford FX2 F-150 3.73 CC 139" WB w/EQ4 WDS
2011 Rockwood 2702SS
frankm is offline   Reply With Quote
Old 08-05-2011, 01:49 PM   #4
ken0042's Avatar
If the tow rating is 2000 pounds and you are pulling a 2500 pound trailer; there are safety concerns. Not grave at that rate, but still a concern.
You seem to be asking two different questions. Can the trailer weigh more than the tow vehicle? Yes, as Ruben said it happens all the time. Look at semis as a classic example.
But if your vehicle has been rated to safely tow 2000 pounds and you add a 2500 pound trailer; you have exceeded the safety rating. Also don't forget a 2500 pound trailer will easily get to 3000-3500 pounds once you add stuff to it.
Personally; I bought a 2800 pound trailer that has a max weight of 3700 pounds. I made sure my tow vehicle could handle 5000 pounds just to be safe.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 08-05-2011, 02:20 PM   #5
prof_fate's Avatar
What would happen? Or what could happen? And when will it happen?
Basically you're overloading the tow vehicle - the cooling system, the transmission, brakes and suspension.
It's not a horsepower issue -the truck will no doubt pull the trailer. If it overheats while doing so then you'll be stranded at the least and in need of a large expensive repair at the worse. The trans may hold up but have it's life shortened - figure $3000 these days for a trans rebuild.
Overload the brakes? You'll crash.
Suspension? Ill handling making for a lousy trip at the least, broken truck perhaps, or a wreck at the worst.
Many factors need to be considered - is he towing in kansas on a flat hiway in 75F temps, or up a mountiain in 100F with the A/C on full tilt and then it begins to pour rain (causing lightly loaded front tired to not brake, not steer...)? And with any safety margin gone there is no 'margin' for error - panic braking, swerving, etc.
Jill & Chris, Wills (11) Evie (8) & Toby our collie (2)
2011 Grey Wolf 28BH
2001 Expedition EB 4x4 w/ Reese StraitLine Dual Cam, 5.7, 3.55
Nights camped 2011: 11 2012: 0 (so far)
prof_fate is offline   Reply With Quote
Old 08-05-2011, 02:27 PM   #6
What is the distance he is going to tow ? What is the tow vehicle ?
Regardless, I would NOT do it .... If someone comes and hits him through no falt of his, his insurance will simply deny coverage because he is doing something illegal. You are not supposed to tow above your tow ratings, period. So he would be out of pocket for all damage and liability. Is it worth it ? He can try to rent a truck or borrow a truck and do the towing with that.
I tow my trailer the 5 miles or whatever it is from storage to my house with no WD bars and of course no sway control. I FEEL the difference ..... Exceeding tow ratings .... he doesn't want to know what might happen ....
2006 Ford F-150 XLT/XTR 4.6l, CrewCab. short bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
Old 08-05-2011, 02:53 PM   #7
Location: Jacksonville Florida - Home of the Jaguars !!!!
vinman72, if his tow vehicle is RATED TO TOW 2,000 lbs, then that is the MAX towing capacity for that vehicle-(which ain't much.) Therefore, a trailer that weighs 2500 lbs is over the limit for that vehicle, and furthermore almost any rental company that I could imagine won't even rent that camper to him IF they know he's pulling it with that vehicle. A good rule of thumb for towing is to tow 75 percent of the max tow rating. So, if you have a tow capacity of 10,000 lbs, you can safely tow a 7,500 lb. rig. AND you still would need the proper hitch and brake setup to do that. I wouldn't tow anything more than a small utility trailer or a jet ski with that vehicle. Randy
'08 V-lite Flagstaff 30WRLS
K&N series 77 intake, Hellwig pro series helper spgs.
'04 Durango Limited Hemi, '72 Mach One 351 cj
Old 08-05-2011, 09:06 PM   #8
Anacortesians
What on earth wimpy TV have you got that's rated at only 2000 pounds? My old Chevy S-10 with the 4-banger engine was rated at 3500.
It's interesting to see what other countries allow. An English RV magazine publishes its "Best Tow Vehicles" every year for a range of different TT weights. They recently did the 2011 review. The best TV for trailers up to 3000 pounds was the Ford Focus. For trailers between 3000 and 3700 pounds they rated the VW Passat the best. For trailers 6000 pounds and more, the winner was the Land Rover Discovery.
I've been trying to find out why the UK ratings are so much higher than the US. My 03 Kia Sedona is rated for 3500 pounds in the us and for 3000 Kg (6600 pounds) in the UK. How do you rationalise such a difference?
Can anyone familiar with tow ratings offer an explanation?
Frank and Eileen
1 Rescued Male Labrador - Bailey, 9 in July
02 Georgetown 325, F53 V10
Old 08-24-2011, 10:48 AM   #9
thebrakeman's Avatar
Neither is a good situation:
1. As already beat to death, if you have a 2000 lbs MAX tow rating, you should not tow more than 2000 lbs. Very simple. To answer your question, if you did, you would be putting yourself, me, and others at risk of life or limb. Don't do it.
2. If you really meant that the 2500 lb trailer is heavier than the tow vehicle, which weighs 2000 lbs, I'd like to know what vehicle you have that only weights 2000 lbs!......and that you think can tow 2500 lbs.
Either way, this does not sound good.
2004 Surveyor SV261T UltraLite Hybrid
thebrakeman is offline   Reply With Quote
Old 08-24-2011, 10:50 AM   #10
But in general, there are plenty of vehicles that can tow more than the weight of the vehicle itself.
In fact, my rig:
5135 lbs empty Mountaineer
7000 lbs MAX tow rating
You have to take precautions, like using a brake controller that will let the trailer "lead" the braking event. Also, most situations like this (or even lighter) will require a WDH setup.
» Online Users: 581
127 members and 454 guests
1l243, acadianbob, accumack, acowie, autorot8, B47, backpacker3, BarrieMark, bean, bigbearZ71, BigJohn2, Biscuit, blaisrv, BlakeB, bob213, brookside, buccello, campfun, CanadianMaple, capucine, cat1956, Celicabob, Cincy6, ColoradoGreg, cyclepuck, Dave_Monica, davidjb, ddavis662, deerslayer, DGrissom, djorgensen3, donn, drb1256, dtb7811, dunnnc, dwcjb, Ed D, elind, f1100turbo, feerobk, Fire Instructor, FreedomTracker, GMS, grhodes50, Hambonethecop, HamptonRoadsRVing, Happy Campers 79, herdrn, hoffkm, itech, Janet H, jcinca, JedinWI, Jeep4Two, Jimmygee, Jo54, justinph, KarenS144, keep camping, kevinC, kingranch, kixonrt66, ktkoch, lami, lemoj1, LFugate, lmcleister, Loopyhamil, Mad4sax, maniac28, mdamm, Medic44, MOLRMEK, mraynie, mrscot, mtnguy, NanaKaren, okdrifter, Old Jeeper, oldiescc, onthelake, Pa-cj5, pandkm, Papa Roo, pappcam, Paul H. Eustace, Poppy Bill, PrairieBoy, punkaccountant, rawlus, Rbonnell, ResQMoore, Rest and Relax, RGH, RJHuser, rjshiflet, ronhanson, rotorhead1250, Rupert Rick, sandpiper, savdog, Scriggs1, SDENN4281, sellis1053, shane1234, Sockman, Steve7575, Taranwanderer, Team Wilhelm, thumper, Timex, Tjah, tking1866, tmmar, tncruiser, tojo70, toleworks, totallystirring, treadwelll, troyt, UPGRADER, Vette4trcr, vlite2011, wa9b, wagon52, WJC, yworrydog
Most users ever online was 996, Yesterday at 11:04 AM.
Close [X]
