Originally Posted by Dawiz
.....Measurements at the front fender are as follows:
Empty 36 3/4"
Loaded no W/D 37 1/2"
Loaded with W/D 37 1/8"......
The bars are returning about 1/2 the weight back to the front. That's about right. Maybe needs just a little more tension on the bars to sink it to 37" or less.
.....The height of the top of the coupling and the hitch are set at 23 3/4" with a level trailer.......
OK. So you know the finished height, once the bars are set up, should be about 23 3/4". Once the bar tension on the hitch is set properly, the ball height can be adjusted to this height.
.....By the time the weight is on and bars connected, the hitch drops to 19"......
This tells me things:
1. More tension on the bars is needed to push the front fender down and the rear fender up slightly.
2. Once 1 is done, raise the ball on the hitch approximately 2-3" to get the trailer riding totally level.
This is a serious trial and error scenario to set up these hitches. My Husky hitch was very similar.
My best recommendation is to get the tension set right on the bars first to allow the front fenders to lower back to your liking. Once that is done, keep the washers and L brackets in the same settings, but only adjusted the height of the ball assembly in order to level out the trailer.
Let us know how it goes.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
