Old 04-09-2015, 11:09 AM   #31
MtnGuy's Avatar
Originally Posted by SeaHarley View Post
Where does the number 44 psi come from?
Do you run this in both the front and the rear "P" rated tires?
Check your tire psi rates before pumping to 44 lbs. My OEM tires were only rated to 35 psi.
Old 04-09-2015, 11:12 AM   #32
Might want to check the max cold temp stamped on the side of the tires.
Old 04-09-2015, 11:41 AM   #33
SeaHarley's Avatar
OK, my door says normal inflation pressure is 35 psi. But my tires say max 44 psi. So now I understand where it comes from.
Tires are: P275/65R18
Thanks.
2012 Lacrosse, 308RES.
2013 Ford F150, XLT, 4x4, Supercrew, Eco-Boost.
Lee, Dawn and "CoCo", the dog!
2015 Overnight Camping Days = 25, States Below:
SeaHarley is offline   Reply With Quote
Old 04-09-2015, 11:57 AM   #34
Scubanut's Avatar
X2 on the dual sway bars.
Scubanut is offline   Reply With Quote
Old 04-09-2015, 12:14 PM   #35
I only have 1 sway bar on my setup below and I never have sway. It's because I've got my WDH set up correctly and my tires up to max. cold pressure so there's no sway with normal driving. I do feel it when I pass or am passed by big vehicles but that's to be somewhat expected with my setup and I never feel out of control.
That being said, I will be adding a 2nd sway bar this summer for those "just in case" situations.
Basically what I'm saying is that those sway bars are only for unexpected conditions where sudden sway could be a problem. With a properly set WDH and correctly inflated tires, there should be no sway at all in normal driving conditions.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is online now   Reply With Quote
Old 04-10-2015, 04:33 PM   #36
Any thoughts on the second part of the tire pressure question? Do you max inflate both front and back, or just the back?
wdbrady is offline   Reply With Quote
Old 04-10-2015, 04:40 PM   #37
IF, you are running P tires, I would go max pressure of 44# front and back.
Old 04-11-2015, 07:51 PM   #38
Went with 44psi on tires and cranked down sway bar real tight
jjacobson71 is offline   Reply With Quote
Old 04-11-2015, 11:14 PM   #39
I'm giving the tire pressure a try on the way home tomorrow. Thinking about LT tires and ordered a second sway bar.
Old 04-13-2015, 12:37 AM   #40
Scubanut's Avatar
I'm using P tires with max psi. The toying was okay before with no real white knuckle moments. But I did know it was back there. When I added the 2nd sway bar is when I didn't really know i was towing. Everything stiffened up and it was very noticeable difference and it added a measure of safety in my opinion.
sway, trailer
