Closed Thread
Old 04-03-2019, 10:46 AM   #1
CentralMePistol's Avatar
Trailer Tires Nitrogen Fill
When I purchased my trailer last year it came with Nitrogen filled tires. Over the winter the pressure has gone down enough that the stem monitors (the green/yellow/red) are showing low on some of the tires.
Can I fill the tire with air and tow it to a dealer to replace with nitrogen? I guess I could remove two at a time?
How have you all handled this?
2018 Cherokee 274DBH
2012 GMC Sierra 1500
4x4, Crew Cab, 5.3 KDL HD Cooling, 3.42 ratio
Recurve R6 WDH w/Sway Control & SumoSprings
Days Camped:2019-18 and counting / 2018-30
CentralMePistol is offline
Old 04-03-2019, 10:49 AM   #2
Flybob's Avatar
This question comes up often. Nitrogen has some benefits, but they are negligible in TT tires. In addition, the air from a compressor is about 78% nitrogen. Fill from a standard compressor and do not waste your time or money on nitrogen.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Flybob is online now
Old 04-03-2019, 10:52 AM   #3
DieselDrax's Avatar
Nitrogen fills are pretty much a gimmick, as long as you fill the tire with low-moisture air you’ll be fine and air is 78% nitrogen anyway.
No need to do anything special. Also, nitrogen will expand and contract with temperature changes just like air. Normal summer pressures will become low winter pressures if there are large temperature changes between seasons.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
DieselDrax is offline
Old 04-03-2019, 10:53 AM   #4
Denver To Yuma In 90 Days
Sounds like your RV dealership sold you another unneeded add-on to your RV.
JohnD10 is offline
Old 04-03-2019, 10:55 AM   #5
Just do a search on "Nitrogen" within the forums. You'll have a few days worth of reading.
Iwritecode is online now
Old 04-03-2019, 11:19 AM   #6
Luckily, no... It was already filled that way when I picked it up- nothing extra.
Thanks for the info, my home compressor should be just fine then.
Old 04-03-2019, 11:36 AM   #7
Yes, your home compressor will be just fine.
As mentioned, even when using your home compressor, the air you will be putting in the tires will contain 78% nitrogen.
Days Camped: '16=46 '17=30 '18=51 '19=27
5picker is offline
Old 04-03-2019, 12:24 PM   #8
hkreck's Avatar
Nitrogen filled tire are just the new scam by the tire industry to increase price as if tires aren't getting expensive enough.
Henry & Tena
hkreck is offline
Old 04-03-2019, 12:29 PM   #9
I just got a great deal on a new "Green" compressor. It puts out 78% Nitrogen into all my tires.
TheWolfPaq82 is online now
Old 04-03-2019, 12:34 PM   #10
Room Air
A tire guy was offering to fill my tires with Nitrogen, when I needed a top off. I told him I already had 80% Nitrogen in them now, plus trace elements of noble gases. He asked "Where did you get that?"
He filled my air with regular compressor air, and I left him no wiser.
2017 Puma Unleashed, 38 ft.
Dodge Ram 2017, 3500, Dually.
KG5TKV
Tiger Force Medic, 68/69
hankpac is offline
Closed Thread
tire, tires, trailer
