Old 04-04-2016, 05:38 PM   #1
Toy-aholic
Trailer wheel balance
I wanted to pass this on for all to consider.....I did a roadforce balance on the wheels of our 5er and was shocked at how out of balance they all were. Most trailer tires aren't balanced from the factory....can't imagine how much shake the trailer was enduring @ 60 mph! The tires show no signs of imbalance either!
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 04-07-2016, 09:00 AM   #2
thebrakeman's Avatar
Etrailer claims that their wheel/tire packages are balanced prior to shipping.
But I haven't actually had mine checked.
thebrakeman is offline   Reply With Quote
Old 04-07-2016, 09:11 AM   #3
clr
Most tire shops that I talked to state that you do not have to balance "trailer tires". Also they state that over a certain size you do not have to balance them, this size is normally 16 inches. But if you go to Goodyear tire service recommendations it states that all tires including trailer tires should be balanced. They also state that the trailer tire may cup or wear abnormally if the tire is not balanced.
So I balance my trailer tires and recommend that you do so also.
clr is offline   Reply With Quote
Old 04-07-2016, 09:25 AM   #4
If a tire is going over 40 mph, it needs balanced whether it's on a trailer or a tow vehicle. Otherwise it will cup.
Old 04-07-2016, 09:36 AM   #5
lswartz's Avatar
While I agree, I have never worn out the tread on a TT. The side walls always go 1st & I use tire covers all the time.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 04-07-2016, 09:38 AM   #6
I get all of my trailer tires balanced. They live longer and so will your suspension parts.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 04-07-2016, 09:53 AM   #7
Witch Doctor's Avatar
X's 2 , I don't know why the RV manufacturers are not required to do this? But it seems they get away with alot...You wouldn't think of not balancing your TV....
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 04-07-2016, 10:01 AM   #8
Another word of warning, if you have TST TPMS Flow thru sensors, use all metal stems and BALANCE WITH THE SENSORS ON. We checked all 5 of mine with and without the sensors, the sensors threw the balance off by 0.5 ozs on all 5. That is enough to cause cupping while towing.
Old 04-07-2016, 10:03 AM   #9
Some guy in back...
it's not "required" because we don't require it!
ChateauV10
SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
ChateauV10 is offline   Reply With Quote
Old 04-07-2016, 10:04 AM   #10
Left Coast
Add shocks
trailer, wheel
