Old 06-05-2015, 05:01 PM   #1
GLCM Warrior
Lefty59's Avatar
Trailer Wiring Fault
Drove to the local campground today in heavy rain & just as we pulled on to our site the TV display said we had a 'wiring fault on trailer' . Truck display gives no additional info on the problem & I could find nothing wrong with the light operations on the trailer. Trailer brakes seemed to be working fine on the drive over too.
Any idea where I should start to isolate the cause? Or should we just chalk it up to something (the 7-pin plug perhaps) got wet? I had left the 7-pin harness laying in the truck bed overnight & we had heavy rain then too.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 06-05-2015, 05:49 PM   #2
Might be water causing the problem - I think a little dielectric grease would help that.
2006 Honda Goldwing
2012 Toyota Tundra DC
2015 Cherokee Grey wolf 19RR Limited
bluewoo is offline   Reply With Quote
Old 06-05-2015, 05:52 PM   #3
F350TH's Avatar
That is usually just a connection problem. Water or the plug came a bit loose from trailer to truck.
2015 XLR Nitro 39DKS5 Toy Hauler
Towed by 2016 Ford F350 CCLB DRW 6.7
F350TH is offline   Reply With Quote
trailer, wiring
