Old 09-15-2018, 05:18 PM   #1
Trailer wouldn’t go in reverse.
I had a freak problem with my 2019 ROCKWOOD Minilite 2506s.
The Factory installed GMC brake controller had a warning saying “Check Trailer Connection”. The electric brakes worked fine going forward, but as soon as I put my GMC Truck in reverse, the electric brakes on the trailer locked up. I was unable to move the vehicle at all. I had to disconnect the 7pin cable between the truck and the trailer in order to move the trailer in reverse. The dealer insisted it was my truck, so I borrowed an F150 from a friend and had the same result.
The dealer didn’t believe me until he reproduced the problem with his own vehicle. After some diagnostics they found a problem with the 7pin cable head on the camper and replaced it. All is fine now.
MMRGOOD is offline   Reply With Quote
Old 09-15-2018, 07:07 PM   #2
Thank you for posting that problem AND the solution. Good to put in the memory bank for 'what if'.
2014 RAM 3500 4x4 diesel
2017 Work & Play Toy Hauler 30WRS
OldGal3 is offline   Reply With Quote
Old 09-15-2018, 07:10 PM   #3
Mr. Dan's Avatar
X2
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 29; booked = 12
Old 09-15-2018, 07:22 PM   #4
Sounds like they had the backup wire and brake wire swapped (pin #2 and #7) on the trailer plug (or more likely back in the junction box).
Name:	7-pin plug wiring.jpg
2011 Traverse LT, 3.6L, FWD
Old 09-15-2018, 08:12 PM   #5
I was thinking the same thing however if that was the case then the brakes wouldn't have worked when going forward. I suspect that if the trailer had back up lights they would light up each time the brake was pushed. I was thinking more likely that pins 7 & 2 were shorted together was more likely. Not saying this was the case but seems possible.
Ironically this reminds me of a similar funny story that happened to me with a cargo trailer. I had hooked up my trailer, plugged in the cable and headed out to get some wood supplies. Everything was going great and working properly (I thought) until I made a right turn. When I turned on my blinker all of the sudden my trailer brakes started activating and releasing jerking the truck each time. Not really putting 2 and 2 together at that time I just pulled over and disconnected the trailer wiring from the truck till I returned home. As you probably already guessed I discovered that the turn signal wire had come loose from the plug connection and was touching the turn signal wire. I can definitely relate to the confusing symptoms that was happening to the OP.
2018 Cedar Creek Silverback 29IK
18 Silverado 3500 HD Dually 6.6 Duramax 4X4
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors w/repeater
Semi-Retired February 3, 2014
Bob & Cindy
Lvn2tvl is offline   Reply With Quote
Old 09-16-2018, 06:18 AM   #6
I think your diagnosis on the short from pins 7-2 makes sense. It worked for 3 trips then failed, so I do not believe it was miswired from the start.
Old 09-16-2018, 01:22 PM   #7
Doubting Thomas
I hate dealing with people like that. Did he apologize? Should have. Glad you got it fixed.
pdqparalegal1 is offline   Reply With Quote
Old 09-16-2018, 06:24 PM   #8
No apology. Just an “I guess you were right”, but I guess I will take that.
Old 09-18-2018, 09:46 AM   #9
Been there done that too.
imjustdave is offline   Reply With Quote
Old 09-18-2018, 09:49 AM   #10
Then you say.. see not all customers are idiots you should listen before dismissing them so quick.
trailer
