Old 07-12-2016, 08:16 AM   #1
Transmission cooler
Any recommedations for a 2016 Ram 1500 5.7L engine? I would like a neat bolt on installation, not one where I have to cut lines and use clamp on rubber hoses.
I'm seeing transmission temps as high as 235 degrees, which concerns me even though my guages and tech say this is within specs even though it is 50 degrees higher than I ran on my 2011 with the same engine.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 07-12-2016, 11:36 AM   #2
235 is not too bad, your engine is running 180-210. I would look at some Ram truck owners forms.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 07-12-2016, 11:42 AM   #3
Perhaps you are right. It just seems hot to me. I will see what she runs in hilly country.
Andersen hitch
Old 07-12-2016, 04:09 PM   #4
grumpy0374's Avatar
Check out Derale Performance. They have the "Good" stuff, not the cheapy 30 buck garbage.
They carry all different types, sizes, clamp on stule, and the good AN fitting type hardware.
I replaced the oe Ford trans cooler, 13 row, with a Derale 40 row stacked plate design that has 3 times to btu heat dissapation of the oe unit.
Not cheap, but not overly expensive for the quality you get.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 07-12-2016, 05:26 PM   #5
Failure is my business
2Evil4U's Avatar
Do you have the 8spd? It has a heater/cooler built in already. Ours runs at 185-190 towing or not.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 24 Cedar Creek 40CBK
2Evil4U is offline   Reply With Quote
Old 07-12-2016, 06:53 PM   #6
Transmission cooler
Do you have tow haul mode on? I was towing on flat road so I took it out of tow/haul and I noticed the transmission temperature starting to go up. Put it back in tow/haul and the temperature dropped back to were it runs when not towing about 180F
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
Happy Vibe is offline   Reply With Quote
