Forest River Forums
Sunline User Photos
Old 05-20-2011, 10:01 AM   #1
Rhime's Avatar
Transmission cooler?
Hi guys,
I thought I'd stay in this forum as it relates to the current trailer I own(Cruiselite 26BH).
I'm looking to install a tranny cooler on my truck and wanted some opinions on what size cooler to get.
I drive a '99 F150 XLT with a 4.6 litre engine.
We live in British Columbia, Canada so there's a bit of climbing involved, but we don't travel long distances.
I understand there's light/medium/heavy duty coolers so what's my best option? If it's heavy duty all the way, then I have my answer
Thanks guys and happy May long weekend!
Rhime is offline   Reply With Quote
Old 05-20-2011, 10:09 AM   #2
Moderator
acadianbob's Avatar
Whenever climbing is involved, a cooler is a very good idea. I'm guessing that you do not have a cooler now based on the limited vehicle info. IMO, why mess around, get a heavy duty cooler. There are some aftermarket coolers that also include a fan and thermostat on the cooler. The fan can be helpful in traffic or at slow road speeds. Good luck on your project!
http://i421.photobucket.com/albums/pp297/acadianbob/IMG_2757.jpg
2012 F150 FX4 Ecoboost, 2008 Surveyor 235RKS
2003 Yamaha FJR1300, Reese Dual Cam WD
1969 John Deere 1020, 1940 Ford 9N
Jonsered 535, Can of WD-40, Hostess Cupcakes
acadianbob is online now   Reply With Quote
Old 05-20-2011, 10:35 AM   #3
You may want to check with Ford, they may have a factory cooler that is made to be added on. GM had one for my Suburban. Just a thought. Also, if it really gets cold up there in the winter, you can over cool your trans fluid and it will not shift correctly.
lowbubba is offline   Reply With Quote
Old 05-20-2011, 10:38 AM   #4
Moderator
mtnguy's Avatar
Rhime, hope you don't mind but I moved this thread into the towing forum, since this involves anyone towing with a automatic transmission, and not just Salem owners.
Your truck probably already has a transmission cooler.....the hydraulic lines from/to your transmission go through a heat exchanger in the radiator. An auxiliary cooler is needed when towing or carrying heavy loads.
I agree with Bob, if you are going to add an auxiliary cooler, might as well go big. The 4.6 L engine is going to make the transmission shift more than the 5.4 L, so all of the more reason to add that cooler.
But, 1st of all, check to make sure you don't already have an auxiliary cooler. On Fords (at least on mine), it is a small heat exchanger in front of and below the radiator......you can see it if you lift the hood and look down between the radiator and grill. If your truck came with a tow package, then you might already have a cooler there.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
mtnguy is online now   Reply With Quote
Old 05-20-2011, 11:33 AM   #5
DF5.4's Avatar
When I had my 99 F-150 with the 4.6 there was a small heat exchanger down low on the passenger side of the truck. That is for the power steering. I added a transmission cooler to mine. It was in series with the cooler built into the radiator. I put it before the radiator to avoid the over cooling issue. I added a transmission temp gauge to keep an eye on things also.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
DF5.4 is offline   Reply With Quote
Old 05-20-2011, 05:29 PM   #6
Moderator
acadianbob's Avatar
That's why the aftermarket kits with a thermostat are nice. They generally don't kick in until trans temp hits 180. And the incorporated fan can be effective.
Old 05-20-2011, 05:33 PM   #7
seven_campers's Avatar
Truecool makes nice aftermarket coolers. Had one installed on our Suburban 1500 and tranny temps dropped significantly when towing.
Could be trucool. Can't remember exactly.
Mike & Joelle + 5
2008 Dodge 3500 CTD, MC, 4x4, SRW,
2009 Sabre 32 BHTS
seven_campers is offline   Reply With Quote
» Online Users: 595
132 members and 463 guests
1l243, acadianbob, accumack, acowie, autorot8, B47, backpacker3, BarrieMark, bean, bigbearZ71, BigJohn2, Biscuit, blaisrv, BlakeB, bob213, brookside, buccello, campfun, CanadianMaple, capucine, cat1956, Celicabob, chiro, ColoradoGreg, cpaulsen, cyclepuck, Dave_Monica, davidjb, ddavis662, deerslayer, DGrissom, djorgensen3, donn, drb1256, dtb7811, dunnnc, dwcjb, Ed D, elind, f1100turbo, feerobk, Fire Instructor, FreedomTracker, GMS, grhodes50, h20ski, Hambonethecop, HamptonRoadsRVing, Happy Campers 79, Happy Vibe, herdrn, herk7769, hoffkm, itech, Janet H, jcinca, JedinWI, Jeep4Two, Jimmygee, Jo54, justinph, KarenS144, keep camping, kevinC, kingranch, kixonrt66, ktkoch, lami, lemoj1, LFugate, lmcleister, Loopyhamil, Mad4sax, maniac28, mdamm, Medic44, MOLRMEK, mraynie, mrscot, mtnguy, NanaKaren, NancyTX, okdrifter, Old Jeeper, onthelake, Pa-cj5, pandkm, Papa Roo, pappcam, Paul H. Eustace, polkatronron, pony express, Poppy Bill, PrairieBoy, punkaccountant, rawlus, Rbonnell, ResQMoore, Rest and Relax, RGH, RJHuser, rjshiflet, ronhanson, rotorhead1250, Rupert Rick, sandpiper, savdog, Scriggs1, SDENN4281, sellis1053, shane1234, Sockman, Steve7575, Taranwanderer, Team Wilhelm, TheSasks, thumper, tking1866, tmmar, tncruiser, tojo70, toleworks, totallystirring, treadwelll, troyt, UPGRADER, Vette4trcr, vlite2011, vp22er, wa9b, wagon52, WJC
Most users ever online was 996, Yesterday at 11:04 AM.
Close [X]
