07-29-2015, 12:38 AM
Transmission recovery add
About a week ago I saw an add that came with a scale on tranmission temps.It was about transmissions that gets hot. If anybody has a link that would be great. What I am looking to do is find a cooler that the transmission fluid lines can go to and get them out of the radiator. Should make the engine run cooler and the trans run cooler. It seems this add had something like that. Thank you
05 Silverado Z71 4X4
2013 Forest River X-LITE
Days camped in 2018, 27
07-29-2015, 12:48 AM
Just a member
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
07-29-2015, 02:45 AM
Last fall I purchased and installed a trans temp guage from
GlowShift | Trans Temp Gauges
I am really happy that I can watch the guage and see in real time what my temp is instead of having to worry if it is overly hot...
I mounted the gauge on the windshield pillar and it is out of the way and easy to see. I also added an oil pressure gauge to supplement my idiot light on the dash so I have both on the pillar.
2014 Shamrock 183
07-29-2015, 04:17 AM
My2005 GMC 2500HD that I just traded in had a separate transmission cooler that was in front of the radiator. When towing my 5th wheel it used to run about 200 degrees give or take. My new Diesel with the Allison Tranny runs around 135, big difference from the 4 speed to a 6 speed tranny. If you do not have a transmission cooler, other the the lines connected to the radiator, you may think about adding one.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
07-29-2015, 08:58 PM
Temp gauge looks real good, Maybe this winter as a hot summer just takes it out of me. Where did you put the sensor. Too bad I could not find one that was wireless.My Z71 came with a big trans cooler but from there it goes into the radiator cooler that warms it back up. My 05 1500 has the weak trans so I am trying to make it last. I saw an add in the forum in the last month that said some thing about trans recovery ? It sounded like they had a small cooler that the lines going to the radiator went to instead of the radiator cooler.This might make things run cooler. With no temp guage I don't have a clue if I'm running hot, I look at the graphs on the forum and feel I need to do some thing. Thanks Mike
07-29-2015, 09:10 PM
moondog
I had a neighbor that runs a garage out of his backyard do the install... he said it took him two hours total, but he has a lift so I did not have to crawl under...
the manual link is here for sensor info
http://www.glowshift.com/instruction...ture-Gauge.pdf
install video link here
2014 Shamrock 183
07-30-2015, 04:17 AM
There are lots of instruments that plug into the on board ECU port in your vehicles. They can display most every parameter of your drive train. (trans temps, oil temps, water temp, RPM, engine load, fuel consumption, etc. Similar to these : ScanGauge II - Scan Gauge OBD II Scanner - OBD2 Scan Gauge
They also have the advantage of reading and resetting and engine or trans and sometime brake codes. I have something similar in ALL my vehicles.
07-30-2015, 10:31 AM
Strange. On my 2013 and my current 2015, both 6-speeds, the flow is:
From the trans (lower pipe) to the radiator, from the radiator to the external air cooler, then from the external air cooler (top pipe) back to the trans.
And this is the flow for a 4L60 GM trans....
07-30-2015, 03:05 PM
If this is right this is great.I have not taken the time to trace the lines, I only took a persons word on the flow. This saves me a lot of hassel. thanks Mike
07-30-2015, 03:13 PM
This looks like the easy fix, do you think my 05 silverado will have trans temp in the ECU port. My trailer control had a loom that plugged into a port, I hope it wasn't the ecu port. So this just velcros to the instr cluster. Mike
08-08-2015, 08:20 PM
The trans temp on my 2007 Chevy PU does display, so I would guess it would. But not sure.
08-17-2015, 01:33 PM
Just got back from vacation. Maybe the dealer can find out for me. Thanks everyone for the replys Mike
08-17-2015, 02:25 PM
My Ram 3500 has external tranny cooler and gauge it runs about 165 in hills and 100 deg outside towing our 18,000 lbs 5er. A must have for towing.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
08-18-2015, 11:42 AM
I'm lucky as my Z71 came with a large tranny cooler as part of the off road package. Mike
08-18-2015, 03:45 PM
My Duh-rango has the tow package with external tranny cooler. But no display for tranny temps. So I ordered the BAFX today. Unfortunately I don't think the tranny talks to the PCM/ECM in my Duh-rango.
2017 GMC Yukon
2018 Roo 23 ikss
