Old 07-17-2012, 07:43 PM   #31
KenNTennessee's Avatar
Skipper,
As long as the tranny stays below 200 F it's fine. If it occasionally goes over 200 it will not hurt it, but the fluid life will degraded, so may need changed more often (using the manufacturer's "severe service" schedule).
KenNTennessee is offline   Reply With Quote
Old 10-09-2012, 10:22 AM   #32
BigDaddySC1's Avatar
I have an 01 F250 with a quit a few upgrades including tans temp, boost, egt gauges, and a DP Tuner with a 60hp tow command. According to Ford the normal running temp of these transmissions is 80 degrees above ambient. When we took our Sandpiper out for the first time I had to pull it through town with a lot of stop and go traffic and the tranny hit 195 (ambient was 92) and began cooling down on the open road. I have the stock 7.3 12 row aux cooler but I am thinking of upgrading it to the 6.0 26 or 32 row cooler, from post I've read this will reduce temps by about 25-30 degrees. Have any of you had this done.
BigDaddySC1 is offline   Reply With Quote
Old 08-30-2014, 05:54 PM   #33
2007 WildCat 32QBBS
05CrewDually's Avatar
Most of the 7.3 ford guys do that cooler upgrade. It definitely is an improvement. You and I have different transmissions but I will tell you my trans temp is usually around 160 degrees towing. Trans temp is my last concern.
05CrewDually is offline   Reply With Quote
Old 08-30-2014, 07:53 PM   #34
cstover's Avatar
We did it to my buddies truck. Huge difference. Before he would have to pull over to let it cool down. Now.....no more.
cstover is offline   Reply With Quote
Old 08-30-2014, 08:23 PM   #35
Bryce's Avatar
With a 26row cooler, I run about 50-60deg over ambient unloaded and 60-75deg over ambient with my camper and a GCW of just under 16,000lbs. With the 13row that was installed with my HD4R100 transmission(stock is a 9row in the diesels), unloaded was 60-70 over ambient and 80-100deg over ambient loaded.
That post that brought this up was from 2012, but still good info.
'01 F-250 PSD CC 4x4 SB
'08 Wildwood LE 26TBSS
State's we've RVed in
Bryce is offline   Reply With Quote
Old 08-31-2014, 06:43 PM   #36
acadianbob's Avatar
I think the chart that started this thread may be dated; or at least it may apply to older vehicles. My 2012 F150 transmission runs at 195 degrees; whether towing or not. That's its normal temp. And it doesn't vary much more than a few degrees from that.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 08-31-2014, 06:48 PM   #37
This data is definitely out of date. The new trannys and synthetic fluids are much improved regarding heat tolerance. Its not uncommon to see my trans temp run about 200 when towing. Synthetic fluids can take upwards of 220 without degradation.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 08-31-2014, 06:56 PM   #38
I upgraded my '01 7.3l to a 6.0 size trans cooler bought through Rockauto. It works very well. My trans temps seem to stay about 30-40 degrees cooler than they used to with the original setup. I also upgraded to Valvoline full synthetic trans fluid.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 08-31-2014, 08:40 PM   #39
Bryce's Avatar
Rock Auto tried to ship 2 of those to me, but both showed up crunched with little packing material. I gave up on them and I ended up with a Ford 26row, but even them the first one they shipped showed up damaged.
Old 09-08-2014, 08:38 PM   #40
Too Tall's Avatar
I can't believe this thread went 4 pages before someone finally said this. I absolutely agree with you. Additionally, One size doesn't fit all when it comes to operating temperature of a transmission. With synthetic oil, that chart is outdated and regardless of the oil, I question the source also. Nearly every transmission and rear axles comes with synthetic oil in trucks. That chart may be a rough guideline for transmissions of yesteryear.
Just my opinion.
Too Tall is offline   Reply With Quote
