Old 10-23-2015, 09:06 PM   #81
trbomax's Avatar
The converter is what makes most of the heat unless it is locked up.
trbomax is offline   Reply With Quote
Old 10-24-2015, 08:23 AM   #82
The Big Toe's Avatar
Originally Posted by Learjet View Post
Why would you not want the converter to lock up? That is a good way to overheat your transmission.
I learned something. Also got a little concerned that my 'plan' wouldn't work.
With a 3:31 rear towing my upcoming purchase of a 27' Hyperlite my plan was to barely use 6th gear on the open road.
I was concerned about the constant locking and unlocking of the clutches in the Torque Converter (TC) and about the constant down-shifting from 6th to 5th and back up. Which, in my experience is fairly common on the older trannies and leads to them going up in smoke.
Turns out that --
6R80 Specs & Ratios - F150 Hub
6R80 Specs & Ratios
It features torque converter lockup capabilities in all 6 gears
BT:
Hope that's true because I don't believe I will be able to handle 6th gear lockup with all that resistance behind me
The Big Toe is offline   Reply With Quote
Old 10-24-2015, 01:05 PM   #83
ah finally some information that makes sense!
I towed ( yes past tense just bought a 2015 Titan) with a 2002 chev avalanche and pulling a 2011 coachman catalina 24FBS the trans temp was running 210 - 215 across indiana with 85 degree ambient. I was wondering why everyone else is running temps so low. the avalanche of this era had HD cooling for trailering BUT did not have the aux trans cooler it had a bigger cooler in the rad. I also saw that chart and thought I was cooking the trans slowly, now with this discussion i feel a little better about the trailering thing.
I used a scangauge 2 for trans readings cause the stock engine coolant gauge would go up 25 - 35 degree before showing anything on the dash and it freaked me out.
doneuald is offline   Reply With Quote
Old 10-26-2015, 11:25 PM   #84
Dabmeb's Avatar
Turns out that --
6R80 Specs & Ratios
BT:
It doesn't show what your tv is but I have the 3.31 ratio in my Eco work truck and towed my 9000 pound crossroads with it from BC to Calgary. It had no problem holding 6 th on the flats on cruise control. GCW was 14,900, rated at GCWR15,100. Have to say it towed it better than my 2500 sub with a 7.4 L.
Dabmeb is offline   Reply With Quote
Old 10-27-2015, 07:15 AM   #85
deebarjay's Avatar
it's amazing what these eco's can do...especially with 3:31 gears....seems those pulls on TC1 were long and steep....you dont say how slow you got or how hot and what rpm's....just curious....actually my real question is....do you feel the motor was laboring anywhere.
2008 F250 6.4 diesel with 50 gal aux tank towing a 2015 Rockwood 2109s Minilite.
2015 Miles and nights
10040/31
2016 miles and nights
feb. 380/7......march 540/3
deebarjay is offline   Reply With Quote
Old 10-27-2015, 07:55 AM   #86
I have a 2013 F150 with the V8. I'm putting supersprings and a Hellwig sway bar on it. The Supersprings are already on it. The Sway bar is supposed to be here tomorrow..
Yes, the EcoBoost has some serious oomph but I understand from those that have towed with both that the dropoff is very little in the Coyote V8.
I'm going to find out
Old 03-03-2020, 10:51 AM   #87
I assume by drop off you mean speed. I had a coyote and found it was a great engine but around 60 mph / 100 kph it was sluggish particularly on grades and much worse the steeper they got. I have a 3.5 now and find on hills it is much more responsive. I'm not a fast driver but it drives me nuts not to be able to maintain a reasonable speed on hills without winding the engine up to 4500 + rpm.
Otherwise the coyote is a great engine and being a V8 guy all my life it was hard to make the change. By the way my trailer was 5600 lbs dry and empty.
Spragueman is offline   Reply With Quote
Old 03-03-2020, 10:54 AM   #88
Am I correct in thinking the 2019 f150 3.5 has a 3.55 rear end?
Old 01-11-2021, 07:54 PM   #89
Depends....not all of them
aaronwsummers is offline   Reply With Quote
Old 06-07-2021, 09:17 PM   #90
Mine does but my friends is 3.73
Akewldewd is offline   Reply With Quote
Old 06-14-2021, 02:30 PM   #91
VR51's Avatar
I tow with ‘13 Silverado 1500 6 speed. Going up long, steep grades towing my 3000# trailer here in the Sierra mtn’s my tranny hits 215*. Should I put an aux. trans cooler on it?
Also, would a free flowing muffler help? I ask because a local muffler shop said the stock muffler has 12# back pressure and the Magnaflow they recommended has 3# back pressure and it would make a big difference in the tranny temps.
2013 Chev Silverado 1500 4x4
2020 Forest River RPod 171
VR51 is offline   Reply With Quote
Old 06-15-2021, 09:59 PM   #92
Camping the Natural State
Towed 8000+ on hilly curvy 2 lane blacktop with with 6R80 gen 1 3.5 Eco this past week. Coming home ambient temps were 90-93 with 65% humidity. Towed in manual mode, cruise set on 54. Mostly in 4th gear which is slightly lower ratio than 1:1. Shift down to 3rd on hills. 15psi boost at times. Tranny never got over 203.
2021 Rockwood Ultra Lite 2614 BS
ARhappycamper is offline   Reply With Quote
Old 06-16-2021, 04:05 PM   #93
In my opinion, no. I tow with a 2012 Yukon XL Denali and have made significant upgrades to the cooling system, including a fan-forced Derale transmission cooler. I often see temps on steep climbs over the mountains of 235ºF pulling a 7,000 lb camper. Your Silverado already likely has the factory external transmission cooler and 215ºF is perfectly fine for the 6L80E. In my opinion having studied this issue to death, it would be a waste of money in your case.
"If I can't fix it, I can fix it so it can't be fixed"
2012 GMC Yukon XL Denali - Silver - 117K miles
2007 GMC Yukon XL Denali - White - 217K miles
2021 Alpha Wolf 26DBH-L
Geotrash is offline   Reply With Quote
Old 06-16-2021, 04:12 PM   #94
VR51's Avatar
Thanks to all of you. I’m feeling much better about my tranny situation.
Old 08-22-2021, 05:34 PM   #95
That chart was wrong 20 years ago and it's wrong today-
(2nd post down)
https://www.silveradosierra.com/tran...ot-t12797.html
That chart does not allow for the vast improvements of base stocks, etc., and other improvements made in the last 20 years.
cknsls is offline   Reply With Quote
Old 08-22-2021, 05:49 PM   #96
There is no muffler that has any effect what so ever on a transmission.
Furthermore any power increases put into a vehicle of any kind only serve to likely raise the temp of engine and trans. For the most part the efficiency of eternal combustion engines is rather fixed. So adding power generally means adding more fuel so more fuel burned means more heat created.
Too bad the simpletons who say and feel other wise just couldn't use their heads and think.
NJBreeze is offline   Reply With Quote
Old 08-22-2021, 11:10 PM   #97
Exactly and well said. A tranny temperature of 215º towing over a mountain pass in the summer is just fine and perfectly normal. Today's transmissions and engines are computer montored and will warn you if something gets too hot. Fluids and equipment used today are much better that what was used 20 to 30 years ago.
elchilero53 is offline   Reply With Quote
