Old 06-15-2016, 10:10 PM   #41
Since you haven't bought the SRW yet get a dually. You will be a lot happier towing a 41ft camper
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 06-15-2016, 10:30 PM   #42
Hutch333id's Avatar
Originally Posted by Kenny kustom View Post
Get a dually.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Absolutely get a dually. I have a 40' 5er and pull it with a dually without any problems whatsoever. Just be conscious of your length and height, allow more space when reversing it in to a site and take things steady while you're driving. If it takes you and extra hour a day to get to your destination, so be it. You'll still be able to rest and relax but have a ton of space in which to do it.
Enjoy and good luck with your selections.
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
Old 06-15-2016, 10:41 PM   #43
dwhit's Avatar
Location: Chicago, Rochester now GA/SC at Lake Hartwell
We use F350 for towing 42' 21,000lb 415amp XLR.
It's not used for anything else.
Diesels don't enjoy errand running, shopping, etc. It sits in garage five months/year (2-1/2 month intervals) where it enjoys owner supplied maintenance.
Sixteen year old F150 for LTL work when we're home.
Wife has her own Ford suburban assault vehicle.
ID:	111260   Click image for larger version
ID:	111261   Click image for larger version
XLR 415AMP, F350 Lariat 6.7 DRW, three bikes, NRA Benefactors.
Heart issues-laid up for a spell
dwhit is offline   Reply With Quote
Old 06-17-2016, 10:30 PM   #44
As one who recently switched from SRW to a dually, don't go into this "under-trucked". I pull a 40'Ft as well. The dually is so much more stable and now within safe weight limits of the truck. Safety, stability and handling are greatly improved. Otherwise a rig that size should not be a problem with caution and common sense.
Jordyn is offline   Reply With Quote
Old 06-18-2016, 08:10 AM   #45
head gamez's Avatar
I want to clarify my original post and say that I echo others recommending the dually since you have not yet bought a truck. When I replace mine, it will be a dually. However, what I have works fine and I am under the axle specs so I'm not rushing out to replace it.
2016 Sandpiper 376BHOK
2500HD Chevrolet
head gamez is offline   Reply With Quote
Old 06-18-2016, 08:44 AM   #46
You will be fine. With a 5th wheel, a 40 footer is only 32 behind the truck so in reality, easier to tow then a 32-35ft TT and with a long bed, you can always get that 90 degree Turing radius.
I would say, as long as you have a 1 ton long bed, you should be fine and not limited to any style fiver. I personal prefer the dually towing experience but my last 2 trucks were SRW. Enjoy!
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
Old 06-18-2016, 05:11 PM   #47
I have a 2012 Silverado SRW diesel and I pull a 35ft Cedar Creek and it does a great job but should I buy the 40ft Cedar Creek then I'll trade for the dually.
5er, travel
