Old 09-12-2016, 08:45 PM   #31
Originally Posted by D_B Travelers View Post
Hey Cap'n, where do you find that the double trailer has to be a 5th wheel or gooseneck? Just asking, because I don't find any mention of how the trailers are connected, just the 65' limit. I looked, honest.
Here you go... http://onlinetowingguide.com/towing_laws.html
Krlpj05 is offline   Reply With Quote
Old 09-12-2016, 08:46 PM   #32
For all to see http://onlinetowingguide.com/towing_laws.html
Old 09-12-2016, 09:01 PM   #33
D_B Travelers's Avatar
Originally Posted by Krlpj05 View Post
Here you go... State Towing Laws
Okay...not being argumentative, but I still don't see anywhere it says it has to be a 5er or Gooseneck for the first trailer. Just says you can pull two trailers, with brakes, with lights, etc. I looked on the TXDOT website that I supplied before and they just do not specify the type of trailer either, else you wouldn't see the UPS guys pulling two trailers.
D_B Travelers - 8 nights in 2017, 35 nights in 2016. 1st RV 2014 TT WJ3001w, new 2016 FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
D_B Travelers is offline   Reply With Quote
Old 09-12-2016, 09:23 PM   #34
B and B's Avatar
According to this guide the 101 inch wide Columbus can not be towed in Penn, NJ and Virginia. I wonder how many know this.
Old 09-12-2016, 09:42 PM   #35
Well, I guess you can forget getting the little state stickers for your RV map in those states! Dang...
I have to think (occasionally it happens to me...really) that your state trooper isn't going to pull out his tape measure and note that you are wider than 96". There are a LOT of wide RVs out there now days! Here is AAA website on trailer laws and they even have TX listed as 8' limit on width. TXDOT says 8'6", and USA Today also says 8'6". I would wager keeping these websites up to the minute correct is not on the top of their To Do list. There is a plethora (new thesaurus!) of misinformation out there, but I would bet going to the state's website where you intend to travel is the best bet.
Old 09-12-2016, 09:46 PM   #36
Yikes, note the length limits on trailers - 35' in Maryland, New Jersey, and Oregon. Oregon? Really? I have seen those huge timber hauling trucks on their roads WAY longer than 35'! There are lot of states with 40' limits too. So I guess that new 42'6", 102" wide 5er is not the best choice for my next rig?
Old 09-12-2016, 11:43 PM   #37
2007 WildCat 32QBBS
05CrewDually's Avatar
Don't go by what some editor typed up and posted on some blog. All the links I've seen so far for a cheat sheet on towing laws were full of flaws. Go to the source. Look up the statutes.
Also Recreation Vehicles laws are separate from Commercial Vehicles. I see a lot of comments above confusing the two.
Here's the actual statute from NJ pertaining to Recreational Vehicles.
To sum it up,
Max length on an RV such as a motor home is 45 feet.
Max length of a combination vehicle (truck & trailer) is 65 feet.
Max width is 102" NOT including lighting and awning upto an additional 3" on each side. (Total width may be up to 108" including factory/dealer installed attachments)
39:3-84. a. (13) The maximum overall length of a recreation vehicle including any load or truck camper thereon found or operated in this State shall not exceed 45 feet and no combination of a recreation vehicle with any vehicle, including the load thereon, nor any combination of any motor vehicle with any camping trailer, fifth wheel trailer or park trailer attached thereto, as these terms are defined in section 1 of P.L.1991, c.483 (C.46:8C-10), shall exceed 65 feet in length. Further, the outside width of a recreation vehicle found or operated in this State shall not exceed 102 inches, excluding safety appurtenances such as awnings and lights which are integral to the construction of the vehicle, installed by the vehicle's manufacturer or dealer, and do not extend more than three inches wide on each side of the vehicle, provided however, that such vehicles permissibly exceeding the 102 inch width with their attached equipment or appurtenances shall only be operated:
(a) On roadways having travel lanes at least 11 feet in width, unless prohibited by the Department of Transportation or by a municipality based on safety reasons and marked with signs prohibiting such vehicles; or
(b) On any roadway of the State when such a vehicle is being operated between roadways permitted under subparagraph (a) of this paragraph; and
(i) The location where the recreation vehicle, fifth wheel trailer, park trailer, camping trailer or truck camper is garaged; or
(ii) The destination of the recreation vehicle, fifth wheel trailer, park trailer, camping trailer or truck camper; or
(iii) A facility for food, fuel, repair, services or rest.
b. No vehicle or combination of vehicles, including load or contents, found or operated on any public road, street or highway or any public or quasi-public property in this State shall exceed the weight limitations set forth in this Title. Violations shall be enforced pursuant to subsection j. of section 5 of P.L.1950, c.142 (C.39:3-84.3).
With all that said I do haul doubles from NJ to FL and never had a problem. I'm right at 65' total length.
And it is double towing as seen in my picture below. Double meaning 2 trailers. Triple towing is triple trailers and is rarely if ever used on the east coast anymore. I have a class A CDL with multiple endorsements including double and triple trailer. The definition is clear in the manual and on the exam.
05CrewDually is offline   Reply With Quote
Old 09-13-2016, 08:38 AM   #38
Good info! I would wager that the NJ information is pretty standard verbiage for most of the rest of the states with, of course, minor changes to allowable length. Further, if a State Trooper sees a RV traveling down his interstate with double tow but everything looks tight and secure, I don't think he is going to bother you. You may only be traveling through and not even be in his state in 30 minutes, or you might be stopping to spend money in his state; either way why aggravate someone passing through if everything looks in order?
Old 09-15-2016, 09:22 PM   #39
Can't always get everything in the trailer. 72' long here
2015 GMC Sierra 3500HD DRW
2014 XLR Hyper Lite 30HFS5
Toys-
Yamaha G9 Golf Cart
2010 Harley FLHX with lots of mods
bowtie_guy is online now   Reply With Quote
