Old 05-18-2015, 08:45 PM   #1
Trouble un hitching 2 for 2
Hey everybody. I am new to the TT world as of a few days ago. Both times I have went to uncouple I have had trouble separating the TV ball from TT tounge. I'm using a weight distribution hitch. When I go to jack the tounge off the ball(with the tounge latch open) the tounge jack starts to lift the the TV. I had to have my brother stand on the TV hitch while I jack up the tounge of TT. Ball suddenly,aggressively drops out of tounge. What am I doing wrong/what should I be doing?? (All spring bars and components of wdh removed prior to trying this)
Nash is offline   Reply With Quote
Old 05-18-2015, 08:51 PM   #2
Bowhnter's Avatar
One possibility...When the tongue latch is open it also has to be pulled back to allow the ball to release.
Mike and Susan
Cavalier King Charles - Jack (4) and Sadie (3)
2015 Columbus 320 RS
2017 Ram 3500 6.7 Diesel
Bowhnter is offline   Reply With Quote
Old 05-18-2015, 08:52 PM   #3
Canadiancrew's Avatar
Sometimes if you pull forward just an inch or so it will stop the truck from pushing back on the lever in the hitch.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 05-19-2015, 08:34 AM   #4
etothepii's Avatar
When I open the tongue latch, I usually hop in the truck, put it in neutral, take my foot off the brake from just a split second, then put it back in park. That usually allows the hardware to relieve built up stress, and the disconnecting process is a lot easier from there.
2014 Rockwood 2306
Fastway E2 equalizing hitch
Prodigy P2 brake controller
2011 Ford F150 Ecoboost, Supercab
etothepii is offline   Reply With Quote
Old 05-19-2015, 09:09 AM   #5
Thanks guys. I was thinking that was my issue. Truck position. Hopefully that helps.
Old 05-19-2015, 09:24 AM   #6
Stormrider151's Avatar
What everyone else said plus make sure when you uncouple that the weight of trailer is firmly on the truck. I made that mistake in the beginning and had the same problem you are having.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 05-19-2015, 09:25 AM   #7
A little grease on the hitch ball and coupler may help out also.
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 05-19-2015, 09:27 AM   #8
cdangel0's Avatar
Agreed - a little grease goes a long way to eliminating the "sticking" issue.
Craig & Lynn D'Angelo
Delaware
cdangel0 is offline   Reply With Quote
Old 05-19-2015, 11:41 AM   #9
Tanddhall's Avatar
Yep, as outlined by another above putting the TV in neutral and foot off the brake usually takes off tension that is there while unhitching. Put back in park with parking brake applied and it should release. Even with fresh grease it will sometimes stay in a bind till you release it.
2006 Wildwood 22FBS
2011 Chevy Silverado 1500
Tanddhall is offline   Reply With Quote
Old 05-20-2015, 09:44 PM   #10
Happy Camper
Another "better do first" is chock your TT wheels so if the binding hitch is being caused by the TT looking for level ground, you won't be casing it across the lot.
Johntgif is offline   Reply With Quote
hitch
