Old 02-27-2019, 09:46 AM   #1
Truck Bed Loading Question
Hello, this question does not relate to hooking up a TT to a TV, but has more to do with loading a truck bed.
I could have sworn that I've heard in the past that if you're loading a heavy pallet of block or something else in your truck bed with a fork lift then you should make sure you're emergency break is off? If not you could run the risk of damaging your transmission. A friend said he had never heard of that. Can anyone elaborate on this topic as I can't find any online resources to say one way or another? Thanks!
GreenHorn Hauler
Missouri
TV: 2014 Chevy Silverado Crew (5.3L), 4X4, 6.6 bed, trailer package and break
TT: 2011 Coachmen 28DDS
GreenHorn Hauler is offline   Reply With Quote
Old 02-27-2019, 09:56 AM   #2
Jim34RL's Avatar
Will the parking brake has nothing to do with the transmission. This is an auxiliary set of brake pads/shoes that secure the rear wheels when the truck parking brake is set. The standard braking system is not being used when the brake pedal is not applied, there is no pressure on the main brake system.
You may be thinking of the transmission should be in neutral when the bed is loaded from a fork lift. Maybe you have heard that in the past. This is just a guess, google that and see if you can find anything on transmission in neutral when loading.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 02-27-2019, 10:01 AM   #3
Whenever I am loading the dump trailer or the truck with a fork lift I set the parking brake to limit the truck from rocking back and forth. I was always told that is easier on the parking pawl. The truck will still move but the rocking in the drive train is lessened.
2019 Hemisphere 272RL
2007 Silverado 2500HD 6L
Cabinfever97 is offline   Reply With Quote
Old 02-27-2019, 10:13 AM   #4
The auto transmission has made the parking break useless. Who pulls there parking brake? When I drove manual stick shifts I always used it, now never. The worst thing you can do is pull a parking brake that is all rusted over.
id be more worried about the fork lift drivers ability to not hit my truck and get the load far enough forward to not kill the truck.
Kimber45 is offline   Reply With Quote
Old 02-27-2019, 11:26 AM   #5
Correct except one point. Many newer vehicles with disk brakes on the rear don't typically use the "drum in hat" set up that they used to where there's basically a drum brake on the inside of the hub/rotor. Most now will simply have a cable actuated lever to engage the caliper.
2019 Rockwood Mini Lite 2509S
2018 F-150 XLT FX4 Crew Cab 3.5EB 3.55
Equal-i-zer E4 hitch 1,000lb bars
pilotpip is offline   Reply With Quote
Old 02-27-2019, 11:44 AM   #6
Semperfi24's Avatar
Originally Posted by Kimber45 View Post
The auto transmission has made the parking break useless. Who pulls there parking brake? When I drove manual stick shifts I always used it, now never. The worst thing you can do is pull a parking brake that is all rusted over..
I am fascinated by this. I was told by Ford that you are supposed to use your parking brake everytime you park. Even with an automatic transmission. Even on flat ground. There is 2 reasons, and you mentioned the second. The sequence as it was told to me, was put the car in neutral, put on the parking brake, then put it in park. It ensures there is no pressure on anything in the drive line. And as you mentioned, the secondary reason to use it, is to prevent rust/seizure. The emergency brake is useless to you in an emergency if you have never used it, and thus, it has rusted and seized in place. But, I'm not in the auto industry, I just know what the dealer told us.
_________________________
2018 Rockwood Mini Lite 2504S
2018 Ford F150 Lariat Special Edition 3.5 Ecoboost
Semperfi24 is offline   Reply With Quote
Old 02-27-2019, 11:44 AM   #7
I've used the parking brake for as long as I can remember. 40+ years would be my guess. I wore a seat belt when wearing seat belts wasn't cool.
I always cringe when I see someone stop their vehicle, shift into park and the vehicle rocks back and forth.
goduc is offline   Reply With Quote
Old 02-27-2019, 12:11 PM   #8
A note of caution:
Failure to use the parking brake can and has resulted in injury and death. See Anton Yelchin cause of death...
myxkp is offline   Reply With Quote
Old 02-27-2019, 12:22 PM   #9
And current F-150s like yours still use the drum brake shoes as well if they don't have an electric parking brake.
The electric versions don't use a cable at all.
babock is offline   Reply With Quote
Old 02-27-2019, 12:35 PM   #10
You want to have the brakes engaged and transmission in park/neutral. The stress that is being put on the parking pawls that lock the transmission can be too much if the weight is aggressively put into the truck and there is nothing to absorb the driveline shock (ie, the brakes). They can get jammed in place or worse. The less amount of driveline shock present, the better.
The parking brake can be your friend and save your life. Even when you hitch your trailer up, you should engage your parking brake and then get out to do your walk around of your trailer (You all do this....right?) before you begin your trip. If there is anything I learned in my years of public safety, it's that complacency kills.
Major Malfunction is offline   Reply With Quote
bed, truck
