03-08-2019, 07:33 AM
#41
Do toppers help with drag
I found over the years that wind direction was a big factor in drag and gas mileage. When I bought a new FR travel trailer with the aerodynamic shaped front, I was amazed at the difference. Adding a topper to the truck never made that much difference.
03-08-2019, 07:36 AM
#42
[QUOTE=BriaBeck;2036700]I'd say that 250-300 lbs is in the ballpark for a good quality topper like Leer, Sportsman, etc. Fiberglass isn't lightweight.
Yep.....I didn't realize how heavy my Leer was until I removed it.....3 of us could hardly lift it.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
03-08-2019, 08:49 AM
#43
My fiberglass top (6.5' bed on Chevy 2500) weights about 200# and has additional hardware so that all windows open (feature will never do without again).
It does make a difference depending on what towing. When I pull my 18' boat, yes the wind is directed over the boat - I can tell as no bugs or trash on my boat windshield. When towing one of the box trailers or my toy-hauler -- I can see the bug line across the front of the trailer. toy-hauler although enormous compared to box trailer does have an air splitter on the nose so is a little better.
does not take a degree in aerospace to simply see that if you can get the airflow over and around the vehicles to be somewhat smoother, you will have a more efficient vehicle. And then we can also discuss the topic of laminar flow and turbulence if you wish...
03-08-2019, 11:00 AM
#44
You are worrying about a gap that you can't close enough to benefit. Bare pickups do benefit from covering the bed or opening the tailgate. When you put a large object behind it you can only try to smooth the airflow between them.
You are, however, forgetting that the big block you are towing creates drag from the air burble behind it. That is why you see air fairings on the back of the trailer on some of the OTR commercial trucks. They want better milage.
A couple of people have mentioned AirTabs which I personally use on my 2018 FROG class A driveable block. I noticed improvement in handling, an improvement in mileage, and know from 18 years on my previous coach they do help with the mileage. The help you can get is going to come from the back of your trailer.
Smooth the airflow behind your rig and you will improve your mileage. FMCA magazine had an article about AirTabs in a January issue about 2012 - 2015 ( I don't remember which year) where a guy in CA did a recorded test while installing them. He gained 1/2 mile to the gallon with no other changes.
I suspect that you can gain a little help from putting them on the side of your bed at the back to smooth the airflow between your truck and trailer. Some on the top rear of the cab couldn't hurt. The weight to cover your truck and your trailer would be about 5 pounds.
They aren't cheap but they can save you money. Check the website and do your homework, then make your decision.
03-08-2019, 11:03 AM
#45
Trailer Park Supervisor
Studies have debunked this.
Yes, I drink the water!
03-08-2019, 03:26 PM
#46
Retired Panpsychist
X2.
A memorable test debunking this myth was deftly executed by The Mythbusters in Episode 64. However, they did get good results from using a mesh tailgate.
Theo & Carol
2007 GoldenDoodle ("Cooper") R.I.P.
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
03-08-2019, 04:07 PM
#47
Mesh tailgate - open tailgate, what's the difference? Bare pickup - not towing, I will have to check out the Mythbusters episode. Tonneau cover might not improve mileage but it would stop the airflow from hitting against the tailgate causing drag. Why would you want to have air hitting a closed tailgate?
I also mentioned that the big gain would be from having reduced drag at the back of the trailer like the OTR truckers do. Push 18 wheels for a while, that is an education
03-09-2019, 05:10 PM
#48
Aerodynamics isn't always obvious to the naked eye, or one's intuition. Air doesn't always behave as we think it does, or as we think it should.
Brian & Becky
2018 Avenger ATI 27RBS
03-09-2019, 06:14 PM
#49
Denver To Yuma In 90 Days
This was all hashed out here a few months back...
I remember that it was proven that a pickup gets better gas mileage with the tailgate up that when down or removed
They are designed to flow the air over the top of the cab and over the top of the tailgate...
A flat cover doesn't help, but a topper does.
Don't ask me for a link...
I'm sure Google can find it!
03-09-2019, 06:26 PM
#50
Had one on my Titan. Other than additional weight and cost the only down side I found was the restrictions when hauling things. No tall stuff, cant stand in truck bed, limited cargo capacity. Will not put one on another truck. And it did nothing for gas mileage.
03-09-2019, 09:26 PM
#51
See with your own eyes a wind tunnel test to show how turbulence/drag plays out with tailgate up or down.
03-09-2019, 09:46 PM
#52
Guy in the wind tunnel test u-tube said that a tonneau cover is better than an open bed, at least on a F-150.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
03-14-2019, 05:01 AM
#53
When we bought our 5ver I had to sell my cap since it wouldn't be used and I miss that cap every day.
03-14-2019, 07:49 AM
#54
Same here ..
Thinking about going back to a smaller TT and getting another topper.
