Old 05-24-2015, 03:51 PM   #1
truck height
Hello all, I could use some insight and information please. I am interested in a sierra select 32qbbs fifth wheel, does anyone know how tall it is from the ground to the camper body at the pin box? the '07 ram 2500 is approximately 57" from ground to top of the bed and i'm worried there would not be the minimum 6" clearance from bed to camper. Any help would be greatly appreciated. thank you
greg p is offline   Reply With Quote
Old 05-25-2015, 06:33 AM   #2
GB
gbrown's Avatar
I have a 2015 RAM 2500 and a 2015 Heritage Glen 327RES and it is impossible to level the unit when towing because of the height of the truck. RAM has literally put themselves out of the fifth wheel market by making their trucks so high. I had a 2010 F250 before and did not have this problem The only way you can be sure is to hook it up and see.
2015 Ram 2500 SLT 4x4 Cummins
2015 Wildwood 327RES
Pullrite Superglide 16k
gbrown is offline   Reply With Quote
Old 05-25-2015, 08:13 AM   #3
wow, thank you gbrown, that's disheartening to hear.
Old 05-25-2015, 10:31 AM   #4
Jim34RL's Avatar
Are you sure it is just Ram? I have read this complaint on the new Ford and Chevy/GMC pick-up bodies also.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 05-25-2015, 12:14 PM   #5
Fulltime family RVer
truck height
My 4x4 '12 Ram does just fine with my '13 Sabre. They're level and I have 6" of clearance.
Maybe the newer ones are even higher. But, thinking about it- the Sabre has big 16" wheels and sits quite always off of the ground. I'd actually like to swap my steps for a set of 4-steps vs. the 3 that is currently on it.
ependydad is online now   Reply With Quote
Old 05-25-2015, 12:17 PM   #6
GB
gbrown's Avatar
Yes, I think all the manufacturers are making the trucks higher. The best option is to stay clear of the 4x4s. Unfortunately nearly all the trucks on the lots are 4x4s because of the increased profit margin. If you want a 4x2 set up for towing it almost always has to be special ordered. My bad for purchasing a 4x4 off the lot instead of ordering a 4x2.
Old 05-25-2015, 12:26 PM   #7
GB
gbrown's Avatar
I think my situation is a combination of the Heritage Glen being a little lower to give more head room in the bedroom and the truck being a little higher that previous years to meet current trends. I contacted Forest River about options to raise the unit and their reply was to go to my local outfitter. In other words, no help from Forest River. It would be nice if they sold a kit to raise the unit a couple of inches. All that is needed is the proper size steel blocks and some longer U Bolts. I will probably do this myself after the factory warranty expires. For now, I'm stuck pulling it nose high.
Old 05-25-2015, 12:39 PM   #8
Tonkatoy77's Avatar
You could always put drop shackles on the rear of your pickup to bring it down a little ways.
Tonkatoy77 is offline   Reply With Quote
Old 05-25-2015, 12:48 PM   #9
B and B's Avatar
The nose high puts a lot of stress on the rear axle. Can you flip axles? I know I have a lift kit on my Dexter Torsion Bars.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 05-25-2015, 01:04 PM   #10
GB
gbrown's Avatar
It's not really an option to lower the truck because it has coil springs all the way around. The axles of the 5th wheel are already under the springs so a flip is not an option. Putting a block between the axle and springs is definitely the way to go after the warranty expires. The trailer has the flex suspension so theoretically there's equal weight on the front and rear tires. This thread on rv.net shows how to do the block lift.
RV.Net Open Roads Forum: Best way to lift a trailer for bigger tires?
truck
