I was under the truck today inspected the leafs real good nothing broken. Shackle bushings are fine as well. GM has specs for the torsion bars to fall between and I will check them and adjust if needed. After some more research I have found this is pretty common having the drivers side sit a bit lower in fact Ford allows up to 3/4 of an inch. I do appreciate all the ideas and feedback
