04-06-2014, 07:49 AM
Truck leans to drivers side
Hitched up my Silverado to my Wildcat for the 1st time yesterday. I noticed I had about an inch less bedrail clearance on the passenger side vs the drivers side. I took her for a test ride and went into a large parking lot. I put a level on the camper and found it to be level then on the truck to wich I found was leaning. I never noticed this on my previous truck (Ram). This leaning did not change with the bags inflated in the Silverado. I unhooked the camper and found even with the bags empty and nothing on the truck it sits 1 inch lower on the drivers side measuring to the rear wheel well. I assume the almost full fuel tank would be alot of the blame here. I have my bags ran off one feed perhaps I should seperate the bags and run a little more on the drivers side when towing? Most wouldnt care and an inch difference i'm kinda anal about stuff like this an inch seems like a big difference in clearance and I can see it when im in the drivers seat looking back.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
04-06-2014, 07:53 AM
Before doing much I would take it to a spring shop and have the springs arch checked and then rearched if needed.
04-06-2014, 07:54 AM
I would be looking for a broken/weak spring. It is definitely not normal unless there is significantly more load on the drivers side.
04-06-2014, 07:58 AM
Campfire Master
Broken or weak spring, or the front torsion bars need adjustment.
John
04-06-2014, 07:59 AM
H2oski
? If you have a short bed 27 Gal fuel @6.8lbs per gal = 183 lbs. I haven't noticed a 1 inch drop on mine.
Have you inspected the rear spring pack on the L\H side for a broken spring. How about any front end work and maybe they didn't put enough tension on the torsion bar?
That's all I can think about.
I have to learn to type faster
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
04-06-2014, 08:04 AM
I would agree that you need to have the springs checked out, the fuel tank full or empty should not be noticeable.
On the lighter side, you must remove mother in-law before checking heights. Lol
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
04-06-2014, 08:06 AM
X2 also if one is broken,or otherwise compromised, I would highly recommend replacing both spring packs. A friend had a broken spring on rear or a f350,found a used one at junk yard, when it was installed,it was stronger than the old remaining spring,he chased the problem, until he found new spring packs. Then all was well. Just my. 2cts. !
Good luck and happy camping !!
04-06-2014, 03:04 PM
Oklahoma Proud
Check the torsion bars they adjust very easily. It is pretty common to have one side an inch different than the other though.
You can also go thru and loosen all the bolts on both side suspensions and retighten them while sitting even- one side shackle may have been changed and tightened down with more load than the other, you never know.
We always replace truck springs in pairs just to help with even sag and rates.
But if it's only an inch, I'd live with it personally unless there was some other issue. Tire size fluctuation and pressures can make differences and sometimes oneside in the sun might make a difference.
MillerTime- Future Sabre Handler!!
04-06-2014, 03:15 PM
Oklahoma Proud
Ok, I was wondering since others said this was not common, and in my experience it has been VERY common, so I just went and measured all 5 of our vehicles.
My d-max and dw's z71 tahoe- drivers side is 3/4" lower than pass. side. (This is at the rear, with fronts even. )
On 2 of my cars the drivers side is 1/4"- 1/2" lower.
The third car, dw's Impala, the pass side is 3/4" LOWER than the drivers side.
As I said in my last post, 1" +,- is no big deal, you will probably find variations on every vehicle.
04-06-2014, 04:59 PM
Wow you must live on a hill, or have a funny tape measure ?
I did notice all are GM products!!
I'm mess'n with ya !!
04-06-2014, 05:03 PM
Oklahoma Proud
Only the best!!
Yeah I didn't measure the International 2 ton. But that thing would do turbs truck test with the bed 4tons overloaded, and it wont give up.
04-06-2014, 05:05 PM
Oklahoma Proud
Go measure your truck, see what you get. Im curious now.
I guess im gonna be walking around work all week measuring every vehicle that rolls in the shop!
04-06-2014, 05:09 PM
Somewhat right of center
I wouldn't even worry about it. To many variables to consider.
2014 Crusader 260RLD Champagne Touring Edition
2013 Silverado 2500 6.0 HD
04-06-2014, 05:22 PM
41 1/2" both sides at the back 39 1/4 at the front right 39" at the front left this is on a concrete driveway.
04-06-2014, 05:31 PM
Oklahoma Proud
Not bad. Do you have bags or not?
None of mine are bagged for what its worth.
04-06-2014, 05:40 PM
No bags just the wimpy springs that came on it...
Heck I've not even bothered to swap out the stock shocks for gas ones yet, poor ol'truck has just under 27.300 miles on it...
04-06-2014, 05:47 PM
Oklahoma Proud
Poor thing.
Sounds like you put miles on trucks like me. Had mine 5.5 years and put 36k on it since then. Now my commuter car....about 25k a year.
04-06-2014, 05:53 PM
Poor thing.
Funny thing, it IS what I drive to work and back five days a week.
Two trips to Centralia WA., Two to OR, one to Portland and one to Newport.
and two trips to Tombstone, AZ. plus the run around miles.
04-06-2014, 05:57 PM
Oklahoma Proud
Must be nice. Im about 100-110 miles a day just to work and back
04-06-2014, 06:00 PM
Ok I bit!
Lf 39 1/4
Rf 38 3/4
Lr 42
Rr 41 1/2
Top of wheel wells, in muddy gravel, driveway. Leaning my head to left ,wind out of NW.
Na it doesn't mean anything. If the op is concerned have it checked at a reputable alignment shop. If a spring is broken ,you would most likely be able to see it.weak,probably not an issue,unladen, but with a large trailer,or 5r,it might be a handling problem in an emergency situation. IMHO
