Old 03-17-2014, 05:34 PM   #21
davel1971's Avatar
Originally Posted by dustman_stx View Post
Wouldn't a certified master tech know that Ford resolved the spark plug issue when it went to 3V heads in 04-05???
With this being said, if you are towing heavy and regularly, go with the 5.9. Otherwise, I see no reason to trade. Keep in mind that the 5.9 rides in a Dodge.
you read all that and didn't see that I'm no longer in the business? When they went to 3 valve heads, they went from blowing out plugs, to plugs you can't get out. The tool kits to get the broken plugs out of the heads arrived at the dealers before the new trucks did. What does that tell you?
David & Lynn
Old 03-17-2014, 06:38 PM   #22
Camper Less Camping
Cajun Po-Boy's Avatar
Buy the Dodge 5.9, rr retired
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 03-18-2014, 07:46 AM   #23
I did see that you said you retired from that business, but your statement said I AM a Ford Master Tech. Plus, as stated above, you seem to have known that the 05 and up trucks didn't have issues blowing plugs, but you stated it anyway. IMHO, the 05 and up 5.4L is a good power plant and tows quite well for what it is(small block V8), is generally very reliable, and gets decent fuel mileage. I see no reason to go to an older Dodge just to get a 5.9 UNLESS he will be towing heavy and regularly.
Edit: I also went back and read another part of your post that was mis-informative. You state the 5.4L will use twice the fuel, which is a very exaggerated statement. A 5.4L will typically get 18-20 HWY MPG unloaded whereas most 5.9 owners I've talked to claim anywhere from 22-25. Loaded heavy, most diesel engines will get 12-14 MPG whereas the 5.4L will get 8-10. You therefore use ~20-25% more fuel unloaded(but as much as 40% more loaded) that is ~10-20% more expensive. Just to reiterate- the 5.9 IS the way to go if hauling heavy and often, otherwise, I'd stay with the 5.4.
Old 03-18-2014, 07:53 AM   #24
avolnek's Avatar
Many other reasons to own a diesel! For the added security of having a much heavier and most likely longer than his current truck. The higher potential resale value, which can be argued due to the higher buy in obviously. Don't forget the shear fact that some people just WANT a diesel and don't need a reason to own one other than they want it... Which is my case, I drive a mile to work and I tow a 37' travel trailer nearing 10,000 pounds in the summer with some misc trailers in between. I went with a diesel mostly because I wanted it! secondly due to the safety factor of having a heavy rig to help steer the trailer rather than my trailer trying to steer the truck...
To the OP be aware that diesels do take more work to maintain to an extent. I am not going to say they are a lot more work, but they do seem to require some more general maintenance than a gasser counter part, but well worth it in my book!
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 03-18-2014, 03:46 PM   #25
An F150 gas can't be compared to an 2500 Dodge diesel. Of course the 2500 Dodge diesel would be much better. The things that I like about my 2011 F250, diesel, longbed, CC, RWD are; much less noise and no dirty black smoke. Good luck
whj77372 is offline   Reply With Quote
Old 03-18-2014, 03:47 PM   #26
I have a 2006 with 90,000 miles on it. The only problem I have had since new was ball joints. Had them replaced at 50,000. Mine is a 6 speed Manuel. One of these guys said to check for blow by. There are some videos on YouTube showing what blow by looks like. Good luck.
bignugget is offline   Reply With Quote
Old 03-18-2014, 03:58 PM   #27
avolnek's Avatar
The noise, and moderate black smoke is exactly why I WANTED a diesel!
Old 03-18-2014, 04:13 PM   #28
AquaMan's Avatar
I enjoy the noise and the smoke at a drag strip, but I wish the ones that have the open stacks and insist on running in low gear all through the campground, just to hear their turbos whine, would go elsewhere. There is a guy in our seasonal campground, that he and I are going to have words this year.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 03-18-2014, 04:25 PM   #29
That's why I detest diesels, smoke, noise and the owners don't know how to shut them off, so they just let the noisy, stinky things idle. Same way with diesel pusher MHs.
Old 03-18-2014, 04:26 PM   #30
Iwannacamp's Avatar
OK... If I were serious about the truck I would take to a shop/trans shop I trust. Pay the $75-100 and have the trans inspected serviced(of course you will have to get permission from the seller). If it checks good then you should be ok. If it's questionable, then negotiate half the cost of a new trans from the seller. IMHO
The trans IS the weak link on all the newer crap.
Iwannacamp is online now   Reply With Quote
truck
