Old 03-16-2014, 03:14 PM   #1
truck opinion
does anyone have a good or bad opinion of 2005 dodge 2500 5.9 automatic. has 105500 miles, thinking about trading my ford for it,
thanks in advance for any thoughts
rr retired is offline   Reply With Quote
Old 03-16-2014, 03:17 PM   #2
Ford Idaho's Avatar
If those are original miles it is very low for that year.
What advantage does the Dodge have over the Ford?
Old 03-16-2014, 03:20 PM   #3
ford is 2009 f150 5.41 gasser
Old 03-16-2014, 03:28 PM   #4
davel1971's Avatar
that's easy, keep the Dodge. We have plenty of 5.9s at work with over 300,000 and are used hard daily. The 5.4 gasser cant touch what you have for power and you will use twice the fuel trying, then it spits the spark plugs out of the heads
David & Lynn
Old 03-16-2014, 03:55 PM   #5
Ford Idaho's Avatar
Is the Dodge wearing any mods such as airbags or other towing equipment?
Old 03-16-2014, 04:08 PM   #6
acadianbob's Avatar
I think he looking at the Dodge.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-16-2014, 04:17 PM   #7
davel1971's Avatar
OOPS, I read it wrong. Here's my new answer. Enjoy your new Cummins powered Dodge.
David & Lynn
Old 03-16-2014, 04:19 PM   #8
semi-senior member
denandra2's Avatar
I have an 06 with same motor and it does a fine job. Miles for that year aren't bad although i only have 68000 on mine. just keep in mind that all fluids and belts and hoses if original would be in need of replacement. If the underside looks clean and no leaks you should get many miles of use out it. It will definitely be a step up as far as towing vs the ford you have. Good luck
Dennis & RuthAnn
Tippy too!
Columbus (2014)320RS
2014 Ram 3500 DRW 6.7HO
Aisin 6speed Auto
SE Mo
denandra2 is offline   Reply With Quote
Old 03-16-2014, 04:21 PM   #9
WFD
OH boy... I see a Dodge vs Ford debate heating up...and very soon someone will throw the GMC in there too even tho the OP isnt looking at a GMC.
WFD is offline   Reply With Quote
Old 03-16-2014, 04:26 PM   #10
davel1971's Avatar
I'm a Ford Master Tech, spent 18 years at dealers before getting out of the business. Look what I drive
David & Lynn
truck
