Old 05-13-2016, 02:49 AM   #1
slickskot's Avatar
Truck question
Hello all!
I just joined these forums after being a visitor for some time, great information on here. My wife and I are looking into getting our first TT and we want it to be a Toy hauler. We are planning on purchasing one in the next couple weeks. It's down to the Wolf pup 17rp or the Grey Wolf 19rr.
Never having a TT before I am wondering if my truck will be OK with it. It's a 2004 Dodge Ram 1500 2x4 with 45,000 miles on it. I've checked out the tow weights and it seems like it should be okay. Just nervous that I'm overlooking something. Any suggestions or info would be appreciated.
Thanks,
Scott
slickskot is offline   Reply With Quote
Old 05-13-2016, 04:32 AM   #2
Bowmanville SVT255S's Avatar
Should be ok if it has a HEMI, But make sure it the trailer you buy can handle the wait of your toy(s) and your truck can haul it loaded.
2015 Ram Crew Hemi
2005 Surveyor SVT 255RS
Bowmanville SVT255S is offline   Reply With Quote
Old 05-13-2016, 04:56 AM   #3
Qwiktime's Avatar
Equalizer sway control hitch would help too!
2002 Avalanche, 2008 Suzuki, M109R, 1979 Malibu, 2016 Grey Wolf 27RR too many toy's not enough time!
Qwiktime is offline   Reply With Quote
Old 05-13-2016, 05:19 AM   #4
RSchleder's Avatar
Scott, you really need to;
A) estimate the total weight of the trailer loaded with propane, batteries, some water, items in the "toy hauler" section, some clothes, food, etc.
B) estimate how much weight you'll be carrying in the truck. Add the tongue weight of the trailer including the weight of the propane bottle(s), batteries, WDH, anything you'll carry in the truck bed, passengers, dog, etc.
1) Once you have these numbers (A), can your truck tow the total weight of the loaded trailer?
2) Does the total loaded weight (B) fall within the load capacity of your truck?
Typically half ton trucks run out of load capacity before they run out of towing capacity. If the weights work out, get a good Weight Distributing Hitch (WDH) , the Blue OX Sway Pro for example, is an excellent WDH unit and if you Google it, you'll get a lot of positive posts. Please let us know if you have additional questions and how you made out. Good luck, Ron
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 05-13-2016, 05:25 AM   #5
davel1971's Avatar
your towing capacity is anywhere from 3300 to 9300. Lots more must be known about truck before any decision can be made
David & Lynn
Old 05-14-2016, 12:21 AM   #6
Retired Techie
As others have said, more about the truck must be known to give you an answer.
I looked at the 19 RR and 22RR also but went with the 26RR because I felt it was a better deal. (And still do)
Typical with the 26 RR was 6800 lbs trailer weight and 700 lbs tongue weight with 900 lb bike loaded. Used a 10,000 lb WDH with 800 lb round bars.
Towed with a 2000 Chevy 2500 6.0 over 6000 miles easily.
2005 Wolf Pack WP22-2016 Grey Wolf 26RR-Gone
2004 Siverado 2500HD Duramax
2013 Keystone Springdale 5r
1998 Honda Valkerie
2016 Camping 148 days so far
moligney is offline   Reply With Quote
Old 05-14-2016, 02:20 AM   #7
asquared's Avatar
In order to better help you, we need to know the truck gvwr, gcwr, payload, tow capacity, engine, and axle ratio. We can't give you an educated answer without this information. Also, what are you planning on putting in the TH garage as using it for an office or dogs to run around in will weigh much differently than using it for a quad or motorcycle etc.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 05-16-2016, 12:38 AM   #8
slickskot's Avatar
The truck does have the 5.7 Hemi magnum in it. 20" wheels with a 3.92 axel ratio. gvwr 6,350 lbs. gcwr 13,000 lbs. gtwr 8,150 lbs. I think I'll be okay, but knowing my luck I just thought it would be a good idea to ask all the questions that I'm worried about before actually buying one.
I will be putting my 2014 street glide in it. I was thinking putting most of the camping stuff in the bed of the truck with my fiberglass tonneau cover on it. It will be me and my wife and our two guard dogs (yorkies) one weighing in at 9lbs the other at 6lbs.
Did look at the 17rp this weekend and a 19rr in person and the wife wants to go with the 19rr.
Thanks again,
Scott
Old 05-16-2016, 12:59 AM   #9
asquared's Avatar
Adding camping stuff to the bed of your truck will subtract from your payload. You are better off loading it in the trailer. Now on average people add 1000-1500 lbs of gear/camping stuff to a trailer. In a toy hauler case that would be in addition to the weight of your street glide. Now in a TH the street glide will help off set your tongue weight some but you still want to try to maintain a loaded tongue weight of around 12-15% of the loaded trailer weight.
Look inside your door jamb for a tire loading sticker. It will say "cargo and occupants should weigh less than X lbs." You need to keep the weight of all passengers, pets, camping gear in truck and tongue weight less than this number. The more accurate way to do this is to find a scale near you, check CAT Scale | Network of Certified Truck Scales. or go to a local dump or feed station. Weigh your truck with all pets, passengers and gear that you plan to have in it when towing. Now take the scaled truck weight and subtract it from the truck gcwr to get your adjusted towing capacity. The loaded trailer weight needs yo be less than this number. Take the truck scaled weight and subtract it from the truck gvwr to get your available payload. The loaded tongue weight needs to be less than this number.
2014 Sabre 34REQS-6
Old 05-16-2016, 03:01 AM   #10
slickskot's Avatar
I am more confused now than ever. My door sticker sticker just has the tire ratio's and GVWR on it. I don't know if it's because it's a older truck or what. I bought the truck when it was a year old way back when and when you look at the door sticker it shows 17" tires not the upgraded 20" that are on it.
One of the reasons we were looking at the 17rp and 19rr is because they were smaller and lighter for my truck to handle.
After reading alot more post I do understand what you are saying about adding the gear to the TH instaead of the back of the truck.
I dont know maybe I need to rethink this whole thing. Last thing I want is to buy something and not be able to use it safely.
truck
