Old 08-14-2015, 09:55 PM   #1
mshell56118's Avatar
Truck Tires
I have a 2010 Silverado 1500 crew cab I pull a 2012 coachman 28dds maybe 6 times a year and the farthest we usually go is about 150 miles away one way. The truck is needing tires and currently the truck has load range e tires 3100lb max load. The tag on the door states p tires which i know i will not get. My question is do you think i need to put e range tires on it or can i get away with tire rated at 2679lb max load. the price difference is significant on the same exact tire. What is everyones thoughts? I also need to get this down pretty quickly and i have a nail in one of the tires and it is where it cannot be repaireed
mshell56118 is offline   Reply With Quote
Old 08-14-2015, 09:59 PM   #2
Your axles are probably only rated for 3900 pounds (1950 per tire) so the lower rated tire should be more than enough with plenty of safety factor built in.
Windjammin is offline   Reply With Quote
tire, tires, truck
