02-12-2019, 06:19 PM
#21
When using a WDH, you are using a lever to lift the rear axle. By doing so it transfers weight. Some of that weight is transfered to the front axle, and considering that the other end of the lever is attached to the trailer some must be transfered to it.
02-12-2019, 07:28 PM
#22
Agreed. Many people don't realize that the WD hitch transfers weight back to the trailer. You will see this effect at the CAT scale when you weigh with bars attached vs bars sitting in the back of the truck.
Engaging the bars has no effect on GCW because the overall weight of the rig is the same, but it does help with payload of the TV some, particularity if you have already counted the weight of the hitch against your payload.
Steve, Barb, and 5 daughters who love to camp
2017 Shamrock 23IKSS, Weight sticker: 5314 lbs, Equil-i-zer 4pt. 1,000/10,000
2006 Fleetwood (Coleman) Niagara: Sold
2004 Suburban 2500 8.1 liter, 4.10, tow rating 12,000, GCWR 19,000, Doorjamb payload: 2108
2003 Suburban 1500 Z71, 5.3/3.73, airbags, LT tires, Big Brake Upgrade, Prodigy P2
02-12-2019, 08:39 PM
#23
If buying from the owner see if you can hook and go I don’t endorse overweight towing but get on the highway see how it handles regardless of the weight if you don’t feel safe then it’s not worth it. Even if under weight if you have “ white knuckle “ experience think twice if you don’t mind the way it handles take it to a scale if within a reasonable range and you like it go for it
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
02-12-2019, 09:29 PM
#24
Good idea Moose, I agree and am requesting that from the seller.
GreenHorn Hauler
Missouri
TV: 2014 Chevy Silverado Crew (5.3L), 4X4, 6.6 bed, trailer package and break
TT: 2011 Coachmen 28DDS
02-12-2019, 10:14 PM
#25
OP you can do it
IMO, you are getting into 3/4 ton territory. But based upon flat Midwest roads and short trips, I’m leaning toward GO FOR IT!
A test run is a nice idea, but will you be able to do it with a WDH and anti-sway bar?
TV - 2020 RAM 3500 Mega Cab SRW with 6.7 Cummins HO & Aisin 6 spd, 4k payload, 23k towing
2002 GMC Yukon XL 2500, 8.1 liter (496ci), 4L85e & positraction with 3.73 gears
TT - 2013 Dutchmen Aspen Trail 3130 QBS
Great bourbon-just about any of San Diego’s craft beer
02-12-2019, 10:22 PM
#26
I'd probably do the same thing for short, flat trips. I always tend to be one of weight police. But if you're using the truck within reason, you'll be fine.
In my case, we'd go from 8' to 5300' above sea level in the same day and our maxed out F150 was getting another passenger (Baby #3). We needed more truck. But a 1/2 ton can make it happen within reasonable expectations.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
02-12-2019, 10:23 PM
#27
Thanks for the comment, Beachbourbon. My intention is to do a test run using the equal-i-zer WDS, drive it on the highway for a bit, and get the combined TV and TT weighed at a CAT scale.
GreenHorn Hauler
Missouri
02-12-2019, 10:28 PM
#28
Check out equalizers YouTube video on setting up the hitch as well. All you need is some wrenches and a tape measure and you can get it dialed in really well.
02-13-2019, 06:09 AM
#29
Likely as not you will be over payload.
The rear will likely need spring help, maybe.
30’ is a big sail and more truck weight will keep the truck on four wheels.
Fuel is not included on factory stickers payload.
You have to load the truck ready to camp with the hitch in the back with the other gear. Then pay the $14 to weigh it. If you read the history on these published numbers it will scare you what went on in the past.
For the trailer use 12% of the maximum weight on the sticker not dry weight for hitch weight. Many are overloaded with water in the tank. We all haul too much.
Will it tow it, sure. You are at or near the 3/4 ton truck line.
Near Branson the truck will not like those hills. Expect 25-30 mph in the slow lane with the engine screaming.
Don’t trust me, weigh the truck.
02-13-2019, 07:39 AM
#30
Gold Tee Box
Originally Posted by Oaklevel
After you think you know where you are weight wise, go to a scale (Like a Cat Scale) and weigh. You might be surprised.
Do this loaded like you are heading to camp.
https://catscale.com/how-to-weigh/
x2
Success is hiring someone to mow your lawn so you can play golf for exercise.
2018 GMC 2500 Duramax Denali
2018 Coachman Freedom Express 287BHDS
02-13-2019, 11:59 AM
#31
Update- Cat Scale and Door Sticker
Last night, when I got home I looked at the sticker on the door and it said "the combined weight of occupants and cargo should not exceed 1550lbs."
The GVWR of the TV is 7200.
I went and fueled the truck up completely and weighed it at a scale with me in the vehicle. Total weight came to 5820 (3440 front axle, 2380 rear axle). According to my calculation that leaves me with another 1380 lbs for additional occupants (wife, small child, dog), cargo (truck bed), and the hitch weight. To play it safe I'm thinking of limiting only firewood (enough for one night as we frequently camp with others) and very light gear like kids toys to the bed (150lbs or less). Coolers and other heavier items that previously went in the bed would go in the TT as it has more room than our last TT.
I also recalculated my hitch weight to include battery weight, equalizer hitch, and tongue weight of the trailer (930lbs). I didn't account for propane tank weight as I called Coachmen and they said they include propane tank weight along with the hitch weight when the camper leaves the floor.
In all, this really leaves a thin margin of available payload in the TV, however I'm still under my calculated GCVWR of 15000 and towing capacity of 9500, but I will confirm that this weekend when I pull the camper to a Cat Scale to measure the gross combined weight of the TV and TT. I also know that I will need to factor in the weight of cargo that we will be putting in the camper as well. If I buy the camper, I will fully load it up before a camping trip and then take to a cat scale by my home.
GreenHorn Hauler
Missouri
02-13-2019, 12:10 PM
#32
Well done. We do have very similar trucks then. My payload sticker said 1511 lbs and weighed in at 6028 with me in the truck plus some gear, tonneau cover and spray on bed liner. Pretty sure the bed liner added a 100 lbs of weight.
On the bright we have a very small trailer so no where near close to payload when it will be loaded.
02-13-2019, 12:27 PM
#33
It appears the OP has a good weight plan of attack.
I expect he will be able to keep below the weight capacities within his rig.
My CAT scale trip was eye opening. I was overweight and no longer haul a load of firewood or any water in the tanks. I removed a LOT of stuff from both TV & TT.
Yes, a WDH does indeed lever some weight to both the front TV axle AND the TT axle(s). My WDH pushed 140# to the TV steer axle and 80# to the TT axle.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
02-13-2019, 12:32 PM
#34
Gold Tee Box
That was a good move!
When you go back, fully hooked up, pay attention to the Front Axle weight of your TV. If it drops a lot, it will give you an indication of how your WDH is set up and if it needs adjustment to throw more weight to the front.
