Old 07-01-2015, 04:37 PM   #1
asquared's Avatar
truck with steering issue
I have a 2014 3500 SRW duramax crew cab/long bed 4wd. I know it's under warranty and do have an appointment scheduled at the dealership but I would appreciate some help figuring out what is wrong before they look at it. It started as what feels like the steering locking up when turning at a slow speed and applying brakes, Pulling into a parking spot or up to a stop sign preparing to turn. This is both directions but right more than left. Initially I questioned if it could be a warped rotor or something. But now, It has progressed to where I feel it when I start the truck and go to pull out. The steering will feel really stiff and heavy. Almost like there is no power steering. I have a great understanding of weights on vehicles but other than that, not much vehicle knowledge. The truck was purchased new April 2014 and has approximately 19,000 miles on it. It is serviced regularly and well taken care of. It is a daily driver and tows my 12,300 lb fiver approximately once a month. It did recently tow up and down a long 8.5% mountain grade without any problems. Thanks
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-01-2015, 08:01 PM   #2
Tonkatoy77's Avatar
Did you check your power steering fluid level? The reason you are having the brake and steering issue at the same time is because they run off of the same system. On a gas vehicle you get power brakes off of the vacuum of the engine. Diesels don't create vacuum. So to get power brakes on your pickup it runs a pump. The same pump as the power steering. It is called a hydro boost system.
2007 Chevy Duramax EFI Live and other supporting mods.
2015 Wildcat Maxx T26BHS
Nights camped 2015....23
Tonkatoy77 is offline   Reply With Quote
Old 07-01-2015, 08:28 PM   #3
asquared's Avatar
Fluids are good, sorry forgot to include that in the OP. Just double checked them. Had a diesel mechanic friend take a quick peek (without tools) and he couldn't see a culprit. Of course it wouldn't do it when we took it for a drive either.
2014 Sabre 34REQS-6
Old 07-01-2015, 08:37 PM   #4
asquared's Avatar
Ok we are getting somewhere. Your hydroboost suggestion may be spot on. I found this when I knew where to look. Thanks
2014 Sabre 34REQS-6
Old 07-01-2015, 08:46 PM   #5
Left Coast
Also, have 'em check the brake caliper to mount area...sometimes the caliper slides get crudded up and won't return fully.....like what was said also, might be belt loosing tension, they don't squeal like the V belts did.
Old 07-02-2015, 11:45 AM   #6
mike.t's Avatar
P/S pump or the Hydro-Boost.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 07-02-2015, 01:04 PM   #7
Sounds like it's in 4WD
Nastyfoot is offline   Reply With Quote
Old 07-02-2015, 05:05 PM   #8
asquared's Avatar
Not in 4wd. Symptoms of hydroboost failure sound dead on. Thanks.
2014 Sabre 34REQS-6
Old 07-02-2015, 07:21 PM   #9
My truck had similar symptoms. Ended up being the steering gear box itself.
JoeNanMinn is offline   Reply With Quote
Old 07-02-2015, 10:22 PM   #10
johngoat2002's Avatar
I had a friend that was experiencing a similar issue. He found out that the pitman arm was worn and binding, but I wouldn't think this would be the case on such a new truck.
2005 Flagstaff FS26
2006 GMC Sierra Denali 6.0L
johngoat2002 is offline   Reply With Quote
truck
