Old 06-23-2014, 04:35 PM   #11
f5moab's Avatar
Originally Posted by OldCoot View Post
Make sure you get the Flow Thru's. The other's are a PITA to add air. I have 4 of them I'll sell cheap.
Just make sure flow thru sensors will fit, or they will exchange them. I purchased my TSTs via the TST website and the flow thru sensors would not fit due to the design of the rim. No problem exchanging with regular ones that fit great.
f5moab is offline   Reply With Quote
Old 06-23-2014, 05:22 PM   #12
Cover Dog's Avatar
Send a message via ICQ to Cover Dog
Old Coot you have a PM.....
Bill, Maura & Rosie the rescued Boston Terrier
2016 Winnegbago Adventurer 38Q....26K Chassis
...traded in 2015 Wildcat 282RKX
2014 CR-V EX-L w/Nav & Blue Ox & Ready Brute Elite
NRA Endowment Life Member, FMCA #455593, WIT #170814 & Mid-Ohio Winnies
Cover Dog is offline   Reply With Quote
Old 06-23-2014, 06:00 PM   #13
Replied and here are pictures of the holder, wrench, etc.
ID:	56180   Click image for larger version
Old 06-23-2014, 06:04 PM   #14
Cover Dog's Avatar
How much $$$
Old 06-23-2014, 06:07 PM   #15
How much $$$
In the pm.
Old 06-23-2014, 07:18 PM   #16
f5moab's Avatar
I'll further explain why sometimes flow thru sensors might not fit.
If you look at the rim, you can see that the valve is inserted into a hold, and the flow thru sensors hit the outer part of the hole, and could not be tightened. I could have added a 1/2 inch extension, but didn't want the sensos sticking out past the rim.
Just a thought on the flow thru, which I would have preferred.
Old 06-28-2014, 07:18 PM   #17
jevanb's Avatar
I bought my 507 non flow thru`s for 285.00 and I got the repeater antenna and a they thru in a 3 year warrantee. only bought it with 4 sensors. ordered the system from the factory. I removed the anti theft covers to save weight on the stems, did not want the flow thru because they a heaver and longer and I can unscrew them to put air in, it doesn't take any more time removing the caps when I did not have the TPMS to add air
507 Starter System Kit |TST Trucking Systems
how much I would like them for the truck
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 06-28-2014, 07:51 PM   #18
Originally Posted by jevanb View Post
...how much I would like them for the truck
Sold, delivered and installed in OH.
Old 06-29-2014, 03:25 PM   #19
golfmedik's Avatar
I love my TST monitoring system. Only trouble I've had is one sensor got water in it and corroded some, but it still works, just periodically loses signal, but with fresh batteries it comes back. Guess I should replace it. The only place I've found batteries for this system continually is Walgreen's. This system gives me piece of mind while towing long trips.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 06-29-2014, 06:52 PM   #20
jevanb's Avatar
I have noticed they run about 10 degrees lower compared to my lazer
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
