Old 08-03-2015, 10:17 PM   #11
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
Originally Posted by Teamfour View Post
We have a TST as well. You can get metal sleeves that will slide over the rubber stem. The bottom of the sleeve fits in the gap of the wheel and the rubber stems won't flex. 6k miles of towing and all is well.
Can you provide more info about them....where can they be purchased?
Lloyd & Kathy & Kit(19 yr old cat)
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi.
2017-65 nights/6992 mi.; 2018-7 nights/1037 miles....9 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 08-05-2015, 07:16 PM   #12
http://www.amazon.com/Chome-Sleeve-C.../dp/B00C79YXE6
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 08-05-2015, 08:07 PM   #13
Thanks......just placed an order for a set.
Old 08-06-2015, 07:22 AM   #14
acadianbob's Avatar
Extremely good information for many here on the forum!
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 08-06-2015, 08:44 AM   #15
Just to be clear, these worked for MY application. Please look at several options on Amazon to determine what may work for you.
Lee and Anne
Old 08-06-2015, 09:03 AM   #16
Auto4's Avatar
My flow through sensors leaked on rubber stems. They did not leak when I tried them on my truck tires that had metal stems. When I called customer service about the problem they stated that they were not recommended for rubber stems. How ever they stated I could file down the brass sensor to get a better seal on the rubber stem. Needless to say I did not file down the sensors and was afraid to mount them until I can get metal stems.
Auto4 is offline   Reply With Quote
Old 09-29-2015, 09:44 AM   #17
Kenny kustom's Avatar
I ordered this.
http://www.amazon.com/gp/aw/d/B00XNVM0EM/
To my surprise.. It came with 6 sensors. Not 4, as stated.
Bonus!
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 09-30-2015, 10:47 AM   #18
Do people remove the sensors when not towing??
2008 F350 CCSB V10
2016 Sabre 36QBOK
Old 09-30-2015, 10:49 AM   #19
BamaBob's Avatar
2008 F350 CCSB V10
2016 Sabre 36QBOK
Yes, you need to - even at a CG if you are there for a few days - if left on the valve stems, it runs the battery down.
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 09-30-2015, 10:52 AM   #20
Only if you want to extend battery life. Suppose to last 10-12 months. I leave mine in for the 3+ months while in FL and take them off when we get home in late Feb/early Mar. I just put them in a couple of weeks ago and will probably leave them in now until we get back from FL. Batteries are cheap and easy to replace.
From TST website:
How long do the sensor batteries last?
On average the 510 sensor batteries last between 5 and 7 years and the 507 batteries are intended to be changed approximately every 10-12 months. The sensors stop transmitting after being disconnected from the tires. If you park your commercial vehicle for extended periods of time or if you store an RV for the winter, you can remove the sensors and extend battery life. The included battery life estimate is based upon full time use.
