Old 05-19-2018, 09:04 PM   #1
TST TPMS flash sale
If you are looking for a tire pressure monitoring system for your RV and have been considering a TST 507 system then the decision just got a little easier. Just found out TST is have a 15% off flash sale. Enter code FR15 when ordering through their website. https://tsttruck.com
BBQGUY is offline   Reply With Quote
Old 05-19-2018, 09:10 PM   #2
woodyrock1's Avatar
BBQGuy is correct! I have the TST 507 and it is great. TST customer service is great and Mike Benson from TST is aces. I just purchased a booster/Repeater using the 15% discount using code FR15. I haven't needed a repeater with my set up but for the price and thoughts of getting a larger 5th wheel down the road I figured what the heck.
Thank you TST & Mike Benson.
05 Ram 3500 Cummins Dually
14 8280WS Rockwood Sig. Ultra Lite
Prodigy 3 brake Controller
TST 507 TPMS
2017 = 30 nights /
2018 = 7 nights
woodyrock1 is offline   Reply With Quote
Old 05-20-2018, 06:21 PM   #3
I've been debating about which one to get, Im not sure if I should get the flow through sensors or the caps? Will either mount to the valve stems? Pros/cons of each type of sensor? Thanks
2012 Ram 1500 Crew Cab Sport
2018 Grey Wolf 22MKSE
straightlinespeed is offline   Reply With Quote
Old 05-20-2018, 06:55 PM   #4
Truck System Technologies Rep
TST TPMS
Hello Sir,
Mike here with TST.
The Flow Through sensors require a metal valve stem, but the Cap sensors can be run safely on a rubber stem.
Typically Motorhomes have a metal stem, Towables will usually have a rubber stem.
Most Motorhomes users prefer Flow Through's and Towables users prefer the Cap sensors.
At the end of the day they are both great sensors, and are very similar the only difference being the size, and one you can add through the sensor the other cap sensor you remove to add air.
Thanks! and remember to use code FR15 at checkout.
I am always available if you have additional questions.
Thanks,
Mike Benson
TST TPMS
210-420-0132
mbenson1234 is offline   Reply With Quote
Old 05-20-2018, 06:59 PM   #5
Originally Posted by mbenson1234 View Post
Hello Sir,
Mike here with TST.
Thanks,
Mike Benson
TST TPMS
210-420-0132
Perfect! Thank you for the quick response and explanation.
Old 05-20-2018, 11:46 PM   #6
KWhite2018's Avatar
Hello Sir,
Mike here with TST.
Thanks,
Mike Benson
TST TPMS
210-420-0132
How long will this sale last?
KWhite2018 is offline   Reply With Quote
Old 05-21-2018, 12:44 AM   #7
TheMusikShoppe's Avatar
I spoke to Mike today and he said that the sale will go on until June 1.
2001 Ford F-350 7.3 dually
2000 Salem T23 (sold)
2015 Vengeance Touring 39R12 (We love it!)
TheMusikShoppe is offline   Reply With Quote
Old 05-21-2018, 01:28 PM   #8
Booster required?
In the past I purchased a flow through type, for the 5er, it kept losing signal from the sensors, I was told to get a booster? for my 35' 5th wheel, is that also on sale ?
jeepin1 is offline   Reply With Quote
Old 05-21-2018, 01:39 PM   #9
Hello Sir,
Mike here with TST.
Thanks,
Mike Benson
TST TPMS
210-420-0132
Mike what impact do the cap sensors have on wheel balancing?
stantyszka is offline   Reply With Quote
Old 05-21-2018, 02:35 PM   #10
Thanks for the info. I was going to order the 510 but for roughly $110 more (with discount), the 507 comes with so much more.
goodguy is offline   Reply With Quote
tpms
