Old 06-24-2015, 11:46 AM   #1
CCRVOC
Ramblin Recks's Avatar
TST507 and the TST510 Monitors
I'm looking for feedback on the monitors of the TST507 and the TST510. Most importantly, which monitor is easiest to read with "old" eyes? I have yet to see either in person.
As for the sensors, I'm leaning towards the 507. Due to the fact it can use the flow thru sensors, which I'll put on the inner duals, and use the standard cap sensors on all the other tires.
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 06-25-2015, 07:07 PM   #2
f5moab's Avatar
Can only speak for the 507. Very easy to read when bright light is hitting the screen, easy to read without the light hitting it. And that is while wearing polarized sunglasses; non-prescription.
I have it mounted on the front windshield left of the steering wheel, just above the dash.
f5moab is offline   Reply With Quote
Old 06-26-2015, 11:40 AM   #3
CCRVOC
That is good to hear (read). Thanks for your input.
Old 06-26-2015, 12:15 PM   #4
Camper Less Camping
Cajun Po-Boy's Avatar
X2...monitor visability was very good during day & night use, sounds and monitor pressure check intervals are good.
I used the 507, very pleased with the product...would buy again
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 06-26-2015, 01:05 PM   #5
Slympicins's Avatar
Ordered our TST507 on Wednesday and received it on Thursday with no additional postage. Had a few questions about pressure settings like I couldn't get the high pressure below 101 for 50psi rated tires. I called TST and they answered on the second ring. No problem just set your lower pressure setting first for all wheels and then go back and set the high pressure below the 101. Came home and poof. High of 61 and low of 45. Heading out for July 4th and we will see how the TST507 works. I can say this, their customer service is fandamtastic.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 06-26-2015, 01:11 PM   #6
Flybob's Avatar
The 507 has a ambient light sensor and will adjust the display lighting accordingly. Unless you have a blinding glare directly behind the display, you should have no problem seeing it. With properly set alarms, you will get comfortable not continuously checking it unless there is an alarm. The company is excellent to work with.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-26-2015, 01:51 PM   #7
Witch Doctor's Avatar
You might be setting that alarm off at the high temp of 61 with your tires aired at 50 PSI. I have been over 11psi on a hot day and pavement. When you called and asked did they recommend 61? I forgot what they set mine at. I called because my low alarm was set wrong and flashing all the time. They said just get your monitor, so I got it and they asked what do you air to, then told me what buttons to push and set it correctly. Once they are coded (the Sensor) then it just a matter of resetting your monitor only. I didn't even know it went into sleep mode til after there help.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 06-27-2015, 12:38 PM   #8
Slympicins's Avatar
I figure I will readjust and watch the temps and pressures. Once I get a common pressure and temp I will close it down to a little over and under. I read where most people do this to get there max pressure and max temp. Then adjust them. Not sure I need a big screen to monitor everything. Once it's set for highs and lows it's dialed in.
Chuck and Joanne
Old 06-27-2015, 12:58 PM   #9
Set the high limit to 20% higher than max cold pressure, so if his max cold is 50, the high limit would be 60, so 61 is close enough. They recommend the same for low, but I set mine at 5# below my max cold of 65 at 60# and high at 78.
I just left the temperature settings where they were.
Old 06-27-2015, 03:41 PM   #10
7 Year Class A RV'er
I went with the TST507 after dumping my non-working, not so old, very expensive Tyre Dog system that the manufacturer would not answer support questions for. Tickled pink with the new system - works great! I got the flow through sensors on the RV and the regular for the toad. Occasionally, I lose contact with one wheel on the toad, so I may need the extender (MH is pushing 40' plus the 4' or so of tow bar to the bumper of the toad and the sensor I usually lose is the toad rear tire, so can't complain). One word of warning that I had to really research to find out. In looking at the model numbers, I thought the TST510 would be the newer model than the 507 due to the numbering - not so. The TST507 is actually the newer model. No idea why they did that but they did. Good luck! By the way, I found the TST507 at CW for the same price as online, but I had to look it up online and tell them their system indicated it as in stock. None on the shelf and they didn't know they had it there until I pushed them to look for it in the back.
2015 Legacy SR340 360RB
