06-10-2019, 03:57 PM
TT hitch will not release properly
Help needed
06-10-2019, 05:09 PM
Without having any additional info I'm just going to take a wild guess as to what your problem is. After chocking the tt tires, be sure to bump the tv forward just a bit to move the hitch ball as far forward in the socket as possible and also make sure there is no upward load from the jack.
2019 Rockwood 2902WS
2019 Ford F250 4X4 CCSB 6.2/4.30
Equalizer E2 with single old-school friction sway control.
06-10-2019, 05:24 PM
I am assuming you are unhitching the trailer. Grease (or lubricate the ball). As noted above chock the TT. I have to raise the hitch pretty good to get my WDH disengaged. Once the bars are removed, I start lowering the hitch with the trailer jack with one hand and trying to pull the decoupler (or whatever that things called that holds the ball in) up and back at the same time with the other hand. My ball usually drops right out.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
06-10-2019, 05:44 PM
Originally Posted by modaholic
Help needed
Does this only occur when unhitching after backing up or does it do it after moving forward too. If it is only backing up, the ball is at the back of the socket and the pawls that grip the bottom it can not release. Once you are set and ready to unhitch, simply move forward about 1/2" and you should be OK.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
06-10-2019, 08:48 PM
That s what I did o n my last two TT , but it doesn’t work on my Forest River Salem Hemisphere
06-10-2019, 10:00 PM
WD 40 and big hammer if none of the above work. My TT from new didn’t like to disengage. So after I unhooked liberal spraying of lubricant and a hammer worked it back in forth till it was smooth. No heavy banging was required just enough to get it working
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
06-10-2019, 10:06 PM
One more thing speaking from experience. If you have someone bump your truck forward to unbind give clear instructions. Trailer was bound up ask the wife to pull it up. I was thinking 1/8 inch she was thinking 8 feet. Yes she was standing there watching and heard me say it was in a bind but none of that meant a darn thing. Don’t assume they know
06-11-2019, 09:26 AM
Depending on which way it's binding you may need to move the TV back instead of forward.
Gotta go campin!
06-11-2019, 10:05 AM
When new the mechanism may be very tight and stiff. It should loosen up with use.
Clean the mechanism with WD40 and then lubricate with spray can of white lithium grease.
06-11-2019, 10:16 AM
Im goann say rock your TV forward just an inch or so.
06-11-2019, 10:33 AM
X2 on the pivoting parts of the mechanism
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
06-11-2019, 10:35 AM
normally a backward bump with the tv will work
06-11-2019, 11:12 AM
Multi-Slacker
I call it the safety catch - what is the correct nomenclature?
We have to jack ours up and down as well as bumping either forwards or backward all the while trying to find that sweet spot. It often helps to jump up & down on the hitch bar or bumper. In our case, it is so bad that we are considering having the cup replaced.
Safe Travels
06-11-2019, 11:17 AM
I read some were that on the hitch coupler that the ball catch underneath or inside that grabs the ball there is a bolt for adjustment to make a little looser if needed. haven't tried but read about it
2019 FR Vibe 28RL
2018 Silverado 1500, Husky Centerline TS
3 Great Danes, 1 Weimaraner
Wonderful co-pilot
