Old 10-02-2012, 11:54 AM   #1
TT pushing truck
When going downhill it seems the TT is pushing the truck, getting high rpm's. Sounds like the truck is screaming. No problem uphill
2009 Ford F150
Rockwood 2703ss
Lady Campers
Tater (grandma yorkie)
Keagan (baby yorkie)
Bandit7 is offline   Reply With Quote
Old 10-02-2012, 12:23 PM   #2
Dave_Monica's Avatar
If you're using the tow/haul feature and cruise control, the transmission will downshift (higher rpm) to try to reduce the speed when going downhill. Disengage the tow/haul or cruise control if don't you want to downshift, or apply the brakes to slow to 5 mph less than you want to go, release the brakes and allow speed to increase, then repeat the process. Do not constantly apply the brakes as they will overheat. On steeper grades I select 3rd gear on the trans to help control downhill speed.
Dave
Old 10-02-2012, 01:54 PM   #3
ironj's Avatar
yup....the truck is "compression braking"....ie using compression from the engine to slow the vehicle/trailer so you dont have to ride the brakes to slow possibly overheating them on long decents....as each stroke of the piston creates a small braking effect, the more rpm the more braking effect you will get. So it is more effective at higer rpm....
its works smilar on a diesel, but not quite exactly
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 10-04-2012, 06:46 PM   #4
I had a 09' F150 pulling a similiar camper and never had any issues like that and it was always in tow haul as it should be.I did feel it slow the truck down but with very little increase in RPM. You do tow in drive and not a lower gear like 3rd? (that is not meant to be insulting) I am not sure ironj but I think the F150's uses the transmission to brake and not compression.
pwrstroke2012 is offline   Reply With Quote
Old 10-05-2012, 07:46 AM   #5
Truck is in drive & tow haul on, no cruise control on
3.55 ratio
Lady Campers
Old 10-05-2012, 07:54 AM   #6
MtnGuy's Avatar
If you can, manually shift the transmission to the same gear used to get up the other side. That used to be the rule for truckers before the advent of the Jake Brake.
Dave_Monica has some good advice.
Old 10-05-2012, 08:02 AM   #7
Herk7769's Avatar
3.55 ratio
That is a "high" rear end ratio, it is possible your engine is working hard trying to slow down your rig because of a mismatch between camper and truck.
Have you checked out whether your truck is actually rated to carry your camper's weight? That is an over 7500 pound camper being towed by an F150 with "middle gears". Depending on your other options your truck may not be rated for that load.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 10-05-2012, 09:13 AM   #8
3.55 ratio
Take it out of tow mode. If you're like most of us, we have what we have and have to make the most of it without trading or upgrading trucks regardless of what the books, manuals say. We may have made an error in matching the trailer to the truck, but we're stuck and have to live with it and find "work arounds".
