Old 06-19-2013, 07:50 AM   #1
Turtle people's Avatar
I recently got a nail in my passenger rear tire ( dual axels) and was wondering what it the best / safest place for a tire jack. Behind the tire on the frame or under the suspension/ axle connection.
Turtle people is offline   Reply With Quote
Old 06-19-2013, 08:00 AM   #2
Between the tires on the suspension framework. DO NOT JACK ON THE AXLES. OR get a trailer tire ramp and forget the jack.
This one I made, but you can buy them at CW.
Trailer-Aid - Camco RV TRAILER AID - Towing Accessories - Camping World
Old 06-19-2013, 08:03 AM   #3
camper1999's Avatar
I jack on the frame, not sure if you can.
2011 GMC 2500HD Diesel
Old 06-19-2013, 08:12 AM   #4
Fulltime family RVer
I asked this same question a month or two ago and here's the summary of the long thread:
- Don't ever jack on the frame - you can damage it. You should jack on the axle.
- Don't ever jack on the axle - you can damage it. You should jack on the frame.
No, seriously - that's essentially what the thread came down to.
I finally chose to jack on the axle as close to the u-bolts as possible. I was at home and bought/used a floor jack for it.
My reasoning was that there is 25" between the ground and the bottom of the frame on my fifth wheel. To get a jack up that high, it would have to be on a rickety pile of wood stacked 10" high. I just didn't feel confident in that.
I did try a ramp out of Lynx blocks with marginal success:
Tire Woes blog entry
It worked for the first tire that I had to change, but after that one - I tried it on the other side and my blocks kept slipping. The ramp that OldCoot made (very similar to a ready-made product) should work pretty well.
Old 06-19-2013, 08:49 AM   #5
camper1999's Avatar
I agree there are mixed reviews on how to do this. I think it comes down to distributing weight. When I use the frame I use two bottle jack one in front of the front axle and one behind the rear axle and jack each slowly. Have been doing it this way for 20 years and on 3 trailers. Using only one jack especially on the axle components can over load the axle part. But if you use two jacks under each axle and jack them equally you do not run risk of over loading the axle. Using the frame has to be done if you need to change shackles or other axle components. But I still believe it comes down to distributing the weight as much as possible.
Old 06-19-2013, 08:54 AM   #6
If it has torsion axles, it is bad to jack on the axles regardless of how many jacks you use. The tubes are thin and contain rubber cords that will be damaged. If you insist on jacking up a trailer with torsion axles, you must jack on the suspension framework and not the trailer frame itself or the axles. Spring suspension is a whole different ballgame.
Old 06-19-2013, 09:01 AM   #7
camper1999's Avatar
totally agree that is what complicates these discussions everyone has different trailers.
Old 06-19-2013, 09:08 AM   #8
I'm planning of making one of these as well. Just wondering what the height is at the back and in the center of the wheel well.....
2012 Ford F150 Ecoboost, max tow/payload
2014 Rockwood 8280WS
2002 Harley Heritage Softail
2006 Club Car Precedent golf cart
dirtman7 is offline   Reply With Quote
Old 06-19-2013, 09:13 AM   #9
I do have spring suspension ( leafs )
So no to the I beam frame the trailer rides on? I like the idea of using 2 jacks to distribute the weight.
Pictures of where to place would be Great. I am still new to this and the last thing I want is a bent frame.
Old 06-19-2013, 09:14 AM   #10
Here's a set of posts where he took pictures and whatnot:
Posts of OldCoot's TrailerAid knock-off
