Old 04-19-2015, 07:02 PM   #1
TT tire size question
I was reading on the forum of some TTs having a problem with very little clearance between the tires and the wheel wells so I decided to check out mine. When I was checking, I noticed that the previous owner had put on tires that are larger than the tires that are listed on the sticker that is on the trailer. The sticker says ST175/80R 13C. The tires are ST205/75R 14. The clearance right now at the top of the tires is about 2". Is this going to cause a problem with the tires rubbing against it or any other problems with having a different size tires than what was originally on it ? The tires are fairly new so I don't want to change them unless I have to.
2011 MicroLite 23LB
2012 Ram 1500 Crew Cab
zinger60 is offline   Reply With Quote
Old 04-19-2015, 09:02 PM   #2
I only have about 2 inches (actually a little less) and have not had any problems. I still check often though because it doesn't seem like enough. Have traveled 16,700 miles and will put on another 4500 this summer.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 04-19-2015, 09:14 PM   #3
Canadian Member
itat's Avatar
Hard to believe your MicroLite 23LB came from the factory with 13" tires. I thought they would have been 14" standard. Is the sticker correct? Maybe others with that model can comment.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
tire
