Old 04-26-2015, 06:47 PM   #1
Thekipkers's Avatar
TT tire wear issues
We got back from our trip today and while cleaning up I noticed a bubble on my sidewall. I went ahead and put the spare on and noticed some strange tire ware. Anyone help me out on what would be causing this
Name:	ImageUploadedByForest River Forums1430092005.243620.jpg
ID:	75321Click image for larger version
Name:	ImageUploadedByForest River Forums1430092019.749409.jpg
Center tread is in great shape inside tread is worn almost completely out.
SK2 CAMPING CREW
2010 Ford F-350
2015 Wildwood XLite 272BHXL
Thekipkers is offline   Reply With Quote
Old 04-26-2015, 06:57 PM   #2
Carknocker Family
Ida Ratherbe Camping's Avatar
Let me guess, factory bias ply tires. Mine wore like that till I went to a radial tire.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 04-26-2015, 06:59 PM   #3
Thekipkers's Avatar
Yeah they are factory tires we have under a year on them
SK2 CAMPING CREW
2010 Ford F-350
Old 04-26-2015, 07:01 PM   #4
Wear on inside is indicative of either loose bearings, bent spindles or bent axles.
Old 04-26-2015, 07:14 PM   #5
Ret E-9 Anchor-clanker
donanddona's Avatar
I once had the inside wear due to excessive turning while backing into a campground spot. This mostly was on concrete and asphalt during the regular camping season. Although excessive once a patterned of wear is established it will forever stay.
donanddona is offline   Reply With Quote
Old 04-26-2015, 07:18 PM   #6
It is my understanding if you wore one on the inside you should of had one with excessive wear on the outside of the other. I agree that once a wear pattern is established, it's there for the remainder of life of the tire unless you have them "trued".
Old 04-26-2015, 07:23 PM   #7
Thekipkers's Avatar
The axle looks straight, it's hard to tell if the wheels are pigeon
SK2 CAMPING CREW
2010 Ford F-350
Old 04-26-2015, 07:24 PM   #8
donanddona's Avatar
I also thought it should have but for what ever reason it did not effect the outer side on the other tire. weird but true...
Old 04-26-2015, 07:25 PM   #9
Thekipkers's Avatar
All tires are showing excessive wear on the inside and was as more wear on the outside then in the center
SK2 CAMPING CREW
2010 Ford F-350
Old 04-26-2015, 07:27 PM   #10
SK2 CAMPING CREW
2010 Ford F-350
IF, you have springs, there should be an upward bow in the center of the axles. If you have torsion axles, you should be able to use a carpenters square and tell if they are leaning in at the top.
tire
