Old 10-11-2012, 06:37 PM   #11
fivecodys's Avatar
Originally Posted by Y_n_R View Post
Currently have a 2010 DBL Cab Tundra hauling a Flagstaff 8528RLWS. Have run approx 5000 miles with no problems. Using a Reese Revolution hitch on the trailer w/a 16k Husky FW.
I have a similar set up as you.
Been 4 years now. No issues at all.
Pleanty of power, pleanty of stopping power.
But, I would still recommend a 3/4 ton truck.
I have added E rated tires and Air bags but it's still a 1/2 ton.
I scale out at 1,200 lbs of pin weight.
Add the hitch, people, and minor cargo and I am very near the GAWR.
With the OP's trailer he will exceed GAWR.
I wouldn't do it.
Maybe a smaller fiver is in order.
Just my 2 cents.
Bill
2009 Flagstaff 8528 RKSS
2007 Toyota Tundra DC 5.7L V8
Pullrite Superglide 14K
Air Lift 5000
Prodigy Brake Controller
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
fivecodys is offline   Reply With Quote
Old 10-11-2012, 06:41 PM   #12
Dave_Monica's Avatar
Does that mean that you're had your set-up across a set of scales and compared them against the truck's towing specs?
Dave
Old 10-11-2012, 06:50 PM   #13
Bill
Our Rockwood 8280WS pin weight loaded was 1240 lbs when I towed with a Ram 1500 which put the the just under it's RAWR. Towed it for 2 years and only had one incidence that I didn't feel comfortable...that was in some 45+ mph cross winds. I wouldn't recommend exceeding any truck's RAWR, but that's just me.
Dave
Old 10-15-2012, 11:09 AM   #14
daydreaming about camping
jeeplj8's Avatar
Originally Posted by sideout1961 View Post
I not a wrench head by any means but why is it called a 1/2 ton if the payload is 1550? Wouldn't that be a 3/4 ton? Just asking.
the term 1/2 ton refers back to a time when that was a fairly accurate description of trucks payload rating. when the truck wars heated up in the 90's every manufacturer started building up their trucks and weight ratings began to climb. The 1/2 ton truck of today borders what a 1 ton was capable of 25 years ago.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 10-15-2012, 12:16 PM   #15
Things keep on going up! My 1/4 ton truck tacoma has a payload of 1430.
tntrac is offline   Reply With Quote
Old 10-16-2012, 01:59 PM   #16
My Tundra CM only has a 1320# payload. You would be way over with that 5'er. I am right on the line with my light SP295 with 750# of tongue weight by the time I add in my family and gear. There are plenty that tow over the limit with the Tundra with no issues, but the fact is that you are still over.
'15 XLR 27HFS
'15 Nissan NVP 3500 SL
Campers - Me, DW, 3 - DS (7, 5, 3), 2 large dogs
CHD Dad is offline   Reply With Quote
Old 11-04-2012, 02:08 PM   #17
Originally Posted by rickthelen View Post
Using an07 tundra, 5.7' 4.1 rear end with airbags to pull a Flagstaff 8528ckss
Dry weight on trailer is 7800. So far so god.
I thought all second generation Tundras had 4.30 gearing in the rear end?
lvnthenw is offline   Reply With Quote
Old 11-04-2012, 06:38 PM   #18
Dovetail's Avatar
You are correct. Memory is failing.
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
Dovetail is offline   Reply With Quote
tundra
