Old 06-23-2014, 08:05 PM   #1
HONDAMAN174's Avatar
Tundra owners- what upgrades have you done?
I know there are a few happy Tundra owners out there towing their TT's with a big smile. My question is what performance upgrades have you made to your beast. Did our first long pull with this setup this weekend- did really well. Other than a 30 mph head wind which caused Clifford to stay in 3rd for about 45 miles-burned thru about 3/8 of a tank on that. Also encountered a 16% grade which even in first gear was starting to bog down
So...what do you guys got under that hood?
Just glad to get away
Old 06-23-2014, 08:18 PM   #2
checca's Avatar
Only added airbags. When towing I use 15/20 lbs to take the bounce out of rough roads . Less on smooth highways. I've always been able to tow in 4th or 5th gear without issues. Maybe try switching to all sync oil and air up your tires to the max on the side wall during towing.
2013 Lacrosse 318bhs
2010 Toyota Tundra Crew max 5.7 flex fuel / Installed airlift ultimate 5000 air bags and smart lift automatic leveling system.
Yamaha EF2000iS 2000 Watt Inverter Generators
Minooka, IL.
checca is offline   Reply With Quote
Old 06-23-2014, 08:40 PM   #3
PhoneDude 8289's Avatar
Added air bags and Bilstein 5100 shocks Auburn limited slip rear end and super charged it. Puts out over 500 HP and 545 #' torque, awesome in the Rockies, rarely drops to third gear and pulls the 8% grades easily at the speed limit. Only difference is because of the super charger she need premium 91 octane or greater, mileage is the same as long as I keep my foot out of it. 10+ mpg towing and 18+ not towing highway. 15MPG in town.
2014 8289WS Diamond pkg
2014 Ram 2500 SB DC TCD
PhoneDude 8289 is offline   Reply With Quote
Old 06-23-2014, 08:44 PM   #4
Jjsav's Avatar
Timbrens, Rear Sway bar and drop in K&N filter. Does a great job. 9 MPG towing. No issues what so ever....
2013 Rockwood 8281SS 5W, Reese Revolution
2012 Toyta Tundra Crew Max 5.7 4x4, Timbrens
Jjsav is online now   Reply With Quote
Old 06-23-2014, 09:17 PM   #5
RPAspey's Avatar
Cold air intake with K&N filter, air bags, rear sway, Bilstein shocks, EBC dimpled and slotted rotors, EBC brake pads fromy and rear, Prodigy P3, 89 or higher gas, full synthetic oil, royal purple axle lube...
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 06-23-2014, 09:21 PM   #6
I run mine stock, pulls 5500# easily.
16% grade will slow all but a 1 ton pulling a pop up. Wow.
John4th is offline   Reply With Quote
Old 08-03-2014, 06:01 PM   #7
mtnjeepers's Avatar
firestone air bags, procomp rear gas shocks, kn filter, getting ready for maiden voyage with the jeep in the trailer fl-nc to go wheein'
mtnjeepers is offline   Reply With Quote
Old 08-03-2014, 06:11 PM   #8
lswartz's Avatar
Mine didn't need anything .
Brakes are another story .
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 08-03-2014, 10:23 PM   #9
Brush's Avatar
Engine is stock but I added Super Springs. I get 8-10 mpg while towing.
Bill and Darlene
2008 Tundra 5.7, 4.30 axle, 8' Bed, 4WD, Super Springs
2009 Rockwood 8319SS Reese WD hitch
Nights camped in 2016(31) 2015(34) 2014(37) 2013(36) 2012(37) 2011(21) 2010(48) 2009(33) 2008(18)
Brush is offline   Reply With Quote
Old 08-09-2014, 07:04 PM   #10
Jr. member & newbie
6,600 towing miles pulling a 7,600 lb TT with 2013 flex fuel DC. Just returned from 4400 mile trip from Alabama to Utah and back, from 500 feet to 8000 feet elevation, and 10-14% grades. Dead stock but have towing package and of course Prodigy 2 controller and 10K Equal-Izer WD hitch.
Tundra has done everything we have asked it to do, and with no problems. We didn't pass many people on the steep hills, but never dropped below 55 MPH nor above 4,000 RPM. I burn high octane during the towing season and am averaging about 9.1 MPG.
After the Utah trip I added the low-bucks version of cold air intake = TRD's low restriction air filter plus the "flow accelerator" piece of the official CAI package. I'm about 400 miles into the 1,000 miles it will take for the computer to react to this change.
NOTE: in your maintenance schedule, you have to change differential fluid and grease the U-joints every 5K miles if you tow a lot. I had missed this and just did all the work yesterday.
hagar is offline   Reply With Quote
tundra, upgrade
