I pull with a Tundra. (see rig below)
I think what you should be looking at is the trailers GVWR not Dry weight.
Dry weight doesn't mean much and in some cases is the weight before any accessories are added.
And nobody travels completly empty, right?
Look at the GVWR of you trailer and see if that falls into the ratings of your truck.
My trailer is 8,600 lbs GVRW.
Well under the rating of the truck.
I have never weighed more than 8,000 at the scales so......I'm good in that aspect.
Pin weight is another issue.
Bill
