Old 05-19-2014, 07:14 AM   #1
Guest
Tundra Towing
Question for Tundra Owner: any overheating issues with the engine or tranny when descending long grades? Will be going through Mont Eagle on our way to Disney in a few weeks. I know I'll be using my gearing and not brakes to control my speed. Trailer weighs around 5500#. Thanks!
John4th is offline   Reply With Quote
Old 05-19-2014, 07:46 AM   #2
dcheatwood's Avatar
I've pulled TT and fifth wheels through smokies, Ozarks and Rockies. Never overheated. Engine size is important. I have 5.7 L. Use tow/haul mode, especially downhill. The gears will assist in maintaining speed down hills. Read about it in owners manual. Understanding how tow/haul works will help you take advantage of it.
Sent from my XT907 using Forest River Forums mobile app
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 05-19-2014, 08:01 AM   #3
Guest
Will the computer do it, or do I use the 'S' on my shifter and manually set the top gear?
Old 05-19-2014, 08:05 AM   #4
JoeR's Avatar
None yet. And I've been towing with the Tundra for the last 5-6 years. And I live in Colorado. And we have a few hills out here, if you hadn't heard.
It's been through several passes and no overheating issues from either, ever.
I use the S mode when heading downhill and usually end up in "3" to control speed.
2008 Toy Tundra DC 5.7L Bagged w/LTs
Hensley Arrow
2012 Windjammer 3001W, Atriumed
JoeR is offline   Reply With Quote
Old 05-19-2014, 08:12 AM   #5
RPAspey's Avatar
I use tow/haul all the time when towing, but my trailer is heavier than yours. When going down long grades, start slow and manually shift the tranny into the lower gears. Pump brakes as needed. I've towed with mine all over hills and mountains. No over heating of engine or tranny. Only weak point I know of is the brake rotors. My OEM rotors warped from the heat of towing. I replaced with high performance EBC brake rotors and pads. Now, no problems.
2000 Cherokee 31BH, "flipped axles and raised",LEDs, solar, inverter, etc..aka "boondock ready". '07 Tundra 5.7L DC-LB, modded as well.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is online now   Reply With Quote
Old 05-19-2014, 08:25 AM   #6
Guest
Both of you are pulling heavier trailers than me for sure. I figured from experimenting it would be around 4th. Gonna be a great trip!
Old 05-19-2014, 08:56 AM   #7
billt01's Avatar
Love my Tundra..
"Camping invloves a tent, bugs, and incliment weather. This aint camping"
-Bill Thomas
Palomino Solaire 317 BHSK
billt01 is offline   Reply With Quote
Old 05-19-2014, 09:41 AM   #8
lswartz's Avatar
Originally Posted by RPAspey View Post
I use tow/haul all the time when towing, No over heating of engine or tranny. Only weak point I know of is the brake rotors. My OEM rotors warped from the heat of towing. I replaced with high performance EBC brake rotors and pads. Now, no problems.
X2. Add rust on the brake pad retaining pins too. I bought cheaper rotors & it has only been 2,000 miles so it is too soon to tell if I made a bad purchase.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 05-19-2014, 09:56 AM   #9
Rugged Brown's Avatar
I see more and more Tundras at the CGs these days. They must be doing allright. I towed my brother's heavily loaded 26' TT from BC to NS 2 years ago. It pulled like a dream, at about 110 km/h. Average fuel consumption was 26 l/100km. Not a single issue and all temps remained constant.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 05-19-2014, 10:08 AM   #10
dcheatwood's Avatar
John. If you have 5.7L and tow package, heres how I do it. Select Tow/Haul on dash panel switch. When starting down hill I hold brakes for a few seconds at the speed I want to maintain and when I let off brakes the gears hold me really close to that speed. On steep declines you'll still slowly gain speed. That's when you hold brakes long enough to slow back to speed you want to maintain. It'll hold there again. Saves riding the brakes.
towing, tundra
