Old 01-04-2019, 12:42 PM   #1
Tundra Towing Experience
My 2012 Tundra 5.7 4X4 closed the year with 13,889.5 miles travelled, 1,328.062 gallons of gas consumed, $3,817.14 spent on gasoline, and an average of 10.46 miles per gallon. Not bad considering 9,992.73 miles was towing a 9,000 lb. 5th wheel on our "west coast walk-about". Our highest altitude was 12,126 feet in Rocky Mountain National Park. The only problem we had was a window in the 5er that broke while leaving Denver's horrible roads. Our 2014 Forest River Flagstaff Classic 8528RKWS performed flawlessly and the Tundra handled grades up to 10% without problems. Actually, we found the east coast mountain ranges to be more difficult than the rockies, but all were doable without any "white knuckle" adventures.
Trawlerphil is offline   Reply With Quote
Old 01-04-2019, 01:24 PM   #2
Prime Member
I have a 10k lb TT that I towed with a Tundra for a year before crunching my numbers and seeing that I was overweight by a large margin. Traded for a Chevy 2500HD diesel. Much better now.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 01-04-2019, 01:29 PM   #3
Thats good performance out of your Tundra.. I always Wonder about the West Coast VS East Coast. While the West coast are longer and higher, Many of the East Coast stuff I Drive in from WV to NC contains alot of those hairpin switch backs that you need to slow to 25 MPH for and then try to get moving again. Can be a workout.
Ron and Kathy
2018 Cherokee Limited 304 BH.
Towed with a 2018 RAM 6.7 3500 G56
ronheater70 is offline   Reply With Quote
Old 01-04-2019, 01:39 PM   #4
Denver To Yuma In 90 Days
While the West coast are longer and higher, Many of the East Coast stuff I Drive in from WV to NC contains a lot of those hairpin switch backs that you need to slow to 25 MPH for and then try to get moving again.
Can be a workout.
Same is true out west...those hairpin curves are hairy!
And those drop-offs are a lot higher!
Someone "doing it for years with no problems" doesn't mean YOU should!
2015 Heartland Prowler P292 5'ver, Reese 16K Pro Slider Hitch
2015 Chevy 2500HD 6.0L Gasser w/4.10 rear end
JohnD10 is offline   Reply With Quote
Old 01-04-2019, 02:10 PM   #5
Multi-Slacker
Really liked our '14 Tundra. Pulled our 9000 ob trailer around the local mountains without issue. But one day, the rear end sag was pointed out to us and we started reading the forums and found out that ours had only a 1400 lb payload. We couldn't get in the truck without being overweight. Now we have an '18 Chevy 2500HD with a 3300 lb payload, Much safer and the headlights stay on the road.
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
Prodigy P3 Brake Controller
Andersen WDH / Class V (2000 lb) Receiver
CurtPutnam is offline   Reply With Quote
Old 01-04-2019, 02:27 PM   #6
Prime Member
Your Chevy must be a gasser. My payload is only 2400lbs but diesel engines are alot heavier.
Old 01-04-2019, 02:44 PM   #7
Multi-Slacker
Yup! Did not want diesel expense or operating hassles. The 6.0 pulled our TT up & down the hills from the Inland Empire to Sedona, Az to Williams to Quartzite without straining. We travel right around 62 mph and, although have not had to, we do not mind slowing down to climb a hill. OTOH, mpg is only about 8.5 when towing.
Old 01-04-2019, 02:53 PM   #8
So In general has your Tundra proven to be pretty reliable towing that weight?
Any accelerated wear on anything? I like the Tundra, If I had a 1/2 Ton Again it would sure be on my list.
Ron and Kathy
Old 01-04-2019, 02:53 PM   #9
Chief T's Avatar
I'm gonna go out on a limb here, and may get some kickback, but the thinner air in the higher elevations increases your MPG. I had lived at sea level in California and now in the SW, and I've always had better MPG in the mountainous/high desert regions.
Safe and happy travels.
2017 Tracer Air 206
2012 GMC Sierra 1500 SLT 6.2l
Days camped 2017: 7
Days camped 2018: 15
Days camped 2019: 4
Chief T is offline   Reply With Quote
Old 01-04-2019, 02:54 PM   #10
Prime Member
I went with diesel mostly for the ease of fueling up. Finding suitable gas pumps that I could navigate through while pulling a 36' TT was a major PITA. I can now fuel up in the truck lanes.
towing, tundra
