Old 05-13-2014, 10:55 PM   #21
I would strongly suggest losing the prodigy and upgrading to a P3. Much smoother working brake controller. (just upgraded mine from a Prodigy to a P3)
Since you are new with towing TT's biggest thing with Tundra's is they have tow capacity in abundance, and it is what alot of salesmen will go by and sell the trailer on. It is still a 1/2 ton truck, and payload (i.e hitch weight) will be the biggest limiting factor. I would say a good rule of thumb is to assume a 14% of your loaded trailer weight as the tongue weight, then add 125lbs for the hitch to that.
My trailer started out with 550lb tongue/5450 lbs GVW dry.
Currently it is 950lbs hitch weight(825 tongue + 125 for the hitch itself)/ 6200lbs GVW.
as you can see it adds up fast. that is for my and my wife only. If you have a family its only going to go up.
If you have a crewmax, the dry weight will probably put you at your maximum payload.
'07 Toyota Tundra 5.7L DC 4x2
'16 Surveyor 226RBDS
Nights camped 2016 - 3
Nights camped in 2015 - 20
Ditchooker is offline   Reply With Quote
Old 05-14-2014, 06:07 AM   #22
Guest
Unless you're hauling a quad runner or a rick of wood, you'll be fine.
John4th is offline   Reply With Quote
Old 05-14-2014, 07:21 AM   #23
Guest
OP most likely has a double cab, as his numbers match mine.
Old 05-14-2014, 10:13 AM   #24
Originally Posted by dave961 View Post
I have a 2011 Tundra and am pulling a similar size/weight trailer. After my first camper/truck I knew I wanted a top notch weight distribution hitch with anti-sway built in. When a semi flies past, it can get exciting if you're not locked in. When towing, I average about 7-8 MPG.
Strait-Line Weight Distribution w Sway Control - Trunnion Bar - 12,000 lbs GTW, 1,200 lbs TW Reese Weight Distribution RP66074
thats fantastic thank you........
howshow is offline   Reply With Quote
Old 05-14-2014, 10:18 AM   #25
Again great info i appreciate all this help!
I have a toyota double cab, 8ft box, 5.7v8, 4x4, w/tow package..... if this helps :/
Old 05-14-2014, 10:23 AM   #26
it will be me, wife and baby, i will more than likely take inflatable zodiac 10' long & the 9.9 motor weighs in at 88lbs, i will probably deflate boat or throw on top of my tonneau cover. usual food blankets camp gear, i think i will be at my max load/tow pretty quick.
Old 05-14-2014, 11:02 AM   #27
Orion's Avatar
Basically agree with everyone else's reply.
I would add if I am towing a 832IKBS (at limits or beyond WP's) you should be fine properly set up with a WDH, at least 1 friction sway bar if applicable to the hitch and something like a P3 Brake Controller.
2017 Flagstaff FLT21DS
2011 Tundra Platinum, 5.7l, 2WD, Firestone bags...
Orion is online now   Reply With Quote
Old 05-14-2014, 11:25 AM   #28
well i have p2 Tekonsha Prodigy P2 Trailer Brake Controller - 1 to 4 Axles - Proportional Tekonsha Brake Controller 90885
i have a WDH and i am adding a TRD sway bar next week, i was also thinking of adding some new front and rear shocks
Bilstein HD Shocks - Best Price on Bilstein B6 Heavy Duty Shocks
Old 05-14-2014, 11:26 AM   #29
dcheatwood's Avatar
If you get an appropriate weight distribution hitch, set it up correctly and use antisway bar, you'll not NEED the airbags. However, the bags will certainly not hurt. That is a heavy tt but the WDH will push some of the hitch weight to the front axle.
I use airbags with my tndra but I tow a fifth wheel and can not adjust weight ditribution like you can on a TT.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 05-14-2014, 11:31 AM   #30
Orion's Avatar
I added those for the rear as soon as I got the truck. Easy and can't hurt
Looking forward to seeing how airbags help mine when going over bridge bumps.. Chuck chuck chuck...
towing, tundra
