Old 04-29-2016, 09:06 AM   #1
dcheatwood's Avatar
Tundras Owners Good Information
I have a 2008 Doublrcab Limited with 5.7L. Recently (Instantly) developed limp mode while wife was driving. 3 dash lights came on, Check Engine-solid, Traction Control-solid, and VSC-flashing. Scanned at Autozone and got a code of P2442. A little checking and I learned that this is the AIP (Air Induction Pumps) AND>>>>Toyota has extended the warranty on these to 10 years - 150,000 miles for year models 2007-2010. So a $3500-$4000 repair will be free next Tuesday.
Here's a chart I found that shows owners' experiences with dash lights that can help you diagnose and possibly find easy solutions to your dash light warnings.
Also a copy of the letter to owners.
2018 Forester 3011 DS
Old 04-29-2016, 09:21 AM   #2
Good news! ....& not surprised.....I have a friend with a 10 yr. old Tundra that Toyota just replaced the entire frame because of rust issues.....the dealer that did the job said it cost Toyota $9000.00.....
Unencumbered By The Thought Process
tande is offline   Reply With Quote
Old 04-29-2016, 09:38 AM   #3
wyo700's Avatar
This is a well known problems for tundras. Surprising that Toyota haven't figured out s better fix. I have a 2013 I'm supposed to have the latest and greatest but owners are still having issues. Seems to be a bigger problem in humid climates. I live in the dry dessert and my dealership has not had any issues. A new ecm update is supposed to stop limp mode. And you may notice with your new pump that when you shut the ignition off you will the pump run for a split second which is supposed to clear out any debris that may have got in there so there will not be a malfunction during next start up.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 04-29-2016, 09:44 AM   #4
dcheatwood's Avatar
Good info. Thanks. I live in wet, humid Louisiana which has flooded the last 2 years and this occurred on a rainy day too.
Caught me by surprise. I've had no issues with mine until this and was not aware of the problem.
Old 04-29-2016, 10:19 AM   #5
wyo700's Avatar
The limp mode is just ridiculous. Turn on a check engine light and that's it. I've read about this happening in the highway and the truck will not go over 40mph. That can cause an accident real quick. And all it is for is emissions to pump air into the exhaust system. Don't see why the engine has to go into limp mode over that.
2013 Toyota Tundra
Old 04-29-2016, 10:43 AM   #6
dcheatwood's Avatar
Exactly! And could be really bad if towing when it happens.
Old 04-29-2016, 02:30 PM   #7
buffalohunter's Avatar
dcheatwood,
Good information - Thanks
Do you have a link to the source of the information? I tried to enlarge it so I could read all of the information but that didn't work so well for me. A URL to the site where you got the information would be much appreciated.
I own a 2007 that I bought new and have serviced every 5K by the local dealer. They never mentioned this issue and I never got "a letter to owners" notification.
Thank you for posting the information.
2012 Rockwood Windjammer 3008 W
2020 Tundra Dbl Cab 4X4 SR5
buffalohunter is offline   Reply With Quote
Old 04-29-2016, 02:57 PM   #8
Don't Camp Enough
DSMURPHY's Avatar
Originally Posted by buffalohunter View Post
dcheatwood,
X2 Thanks for the heads up!
2020 Prime Time Sanibel 3102
2016 F-350 King Ranch
DSMURPHY is offline   Reply With Quote
Old 04-29-2016, 02:58 PM   #9
Post Tundra - Save Image JPG
If you "save image as", give it a name and a location (desktop) you can enlarge it as much as needed.
Retired U.S. Coast Guard Mustang
Presently a librarian @ Duke
2016251RKS is offline   Reply With Quote
Old 04-29-2016, 06:30 PM   #10
Phenom's Avatar
Good info. I never had the issue, but saved the info I found on tundra forums. There's also a bypass procedure I think in case you're out on the road and this comes up. Before I sold my tundra I had that saved as well.
Sean
'16 28DBUD
'16 2500HD Dmax
Phenom is offline   Reply With Quote
Old 04-29-2016, 06:45 PM   #11
banda's Avatar
I had this happen to my 2010 at about 80,000 miles. I hope it doesn't happen again at 160,000 miles, right after the warrant expires! If you get into limp mode you can reset it a couple of times by disconnecting the battery.
banda is offline   Reply With Quote
Old 04-29-2016, 07:42 PM   #12
dcheatwood's Avatar
Good to know. I also like knowing there's a work-around, bypass.
Old 04-30-2016, 07:52 AM   #13
banda's Avatar
I could be wrong but I don't think the bypass is something that can be easily done on the side of the road. I think you have to purchase a device and install it. http://www.tundraheadquarters.com/bl...bypass-module/
Old 04-30-2016, 12:12 PM   #14
dcheatwood's Avatar
That's how I read it also.
Old 05-04-2016, 09:20 PM   #15
dcheatwood's Avatar
Quick followup. I had truck serviced at dealer about 60 miles from home. Both pumps and valves were replaced under the service bulliten, extended warranty at no charge. Runs like new now. Hope this information helps any others who develope the "limp" syndrome.
Old 06-08-2016, 08:56 PM   #16
madmoto375's Avatar
New sound under hood
Great info, thanks for the heads up; I never knew this about the Tundra and had a 2011 until about 3 weeks ago when I traded it in on a 2016. I've never had any issues with my Tundras. This explains the new sound when I turn off the truck. Sounds like a vacuum on the passenger side under the hood and runs for a few seconds after I turn it off. I've been wondering; Now I know...
Truth isn't for sissies
If you're gonna be dumb, ya better be tough.
SFC(ret), USA
madmoto375 is offline   Reply With Quote
Old 06-10-2016, 10:18 PM   #17
dcheatwood's Avatar
Yep. That's how mine started. Like new now since the repair.
Old 06-11-2016, 12:39 AM   #18
banda's Avatar
Hmmm. My new pumps don't run after I turn off the engine. Only when I start it. Hope that's not a problem.
Old 06-11-2016, 08:43 PM   #19
Listen closely and they will come on for just a second or two when you turn off engine , must be @ operating temp.
My wifes 2014 rav4 has a vac pump that comes on with veh off - i hear it in the early A.m. when I go outside to get into my Tundra - just a low buzzing sound from the driver side under body. Its in here owners manual - normal . Emissions/charcoal canister.
Thanks for the info - I had mine replaced a few months after new in 2012.
2006 Honda Goldwing
2012 Toyota Tundra DC s(sold)
2015 Cherokee Grey wolf 19RR Limited
2017 F150 Super Crew 3.5eb 5.5
bluewoo is offline   Reply With Quote
Old 06-11-2016, 08:48 PM   #20
Did the dealer do a re flash of the cpu? After mine were replaced it was a while and toyota had a service campaign. After that was performed my air pumps kick on for a sec as soon as I turn of engine.
2012-2014 Toyota Tundra and Sequoia ECU Software Update LSC F0A (codes P0418 or P2445) | TOYO Headquarters
Lookup Safety Recalls & Service Campaigns by VIN
2006 Honda Goldwing
tundra
