Old 04-12-2012, 12:16 PM   #1
Steve Jackson
sideout1961's Avatar
Turning radius
New to towing a trailer this year. Can anyone tell me how sharp I can turn the TV with the WDH attached? Don't want to do any damage to the truck or trailer.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 04-12-2012, 12:25 PM   #2
Not to be short with you, but when the bumper hits the trailer, you have gone too far. Really, no one can figure that out but you. It depends on hitch, tongue length, and many other variables. Best to get your wife, hook to the trailer, and take to the school parking lot on a week-end, and check for yourself. Besides, if some one posted 44 feet, or 48.3 degrees, would that really mean anything? You have to figure it out for your combination. Take in to account though, that it will vary with incline, whether the truck or trailer is up hill or down hill. Practice in a parking lot, and practice backing the trailer in a parking space. Might come in handy sometime.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-12-2012, 12:41 PM   #3
Steve Jackson
I will take your advice. Just wasn't sure the range of motion that the bars had side to side while attached. Don't really want to damage anything testing it in a parking lot.
Old 04-12-2012, 01:06 PM   #4
I took mine to a deserted parking lot and tested it. I turned it until the bumper almost touched the trailer tongue. My hitch is an Andersen and I had no problems with it. My concern was the difference in tracking between the TV and the trailer. The difference in my case was nine feet at maximum turn.
comfun1 is offline   Reply With Quote
Old 04-12-2012, 01:30 PM   #5
Steve Jackson
Thanks comfun1, I didn't realize they could turn that sharp. Like I said first time at this. I will take it to the mall here and test it out. When I brought the trailer home from the dealer I didn't have a need to do any sharp turns. Thanks again.
Old 04-12-2012, 02:04 PM   #6
One thing I forgot to mention, if you have the brake type anti sway bar, don't back up with it connected. In other words, if your anti-sway device, is a separate piece, held in with two clips, do not back up with it connected. It will be fine to disconnect and practice in a parking lot, but hook it back up for towing home. You won't get any sway at parking lot speeds, or semi's passing you at 80 mph.
LadyWindrider
Old 04-12-2012, 03:02 PM   #7
Not sure which type of WDH you have. On my E2 Equ-a-lizer no issue on making tight turn with bars attached on flat surface but one caution. If your turn involves TV entering into dip (i.e edge of ditch) make sure you remove the bars first. I had some damage to hitch head in this situation but Equ-a-lizer replaced head under warranty.
Roy & Jean
2010 Rockwood mini Lite ETC 181
2002 Toyota Tundra 4.7l 4x4
Prodigy P3, E2 WDH
rschoono289 is offline   Reply With Quote
Old 04-12-2012, 03:47 PM   #8
Steve Jackson
I have the Reese with the duel cam sway control. Thank for the advice everyone.
Old 04-12-2012, 03:53 PM   #9
Terier's Avatar
Windrider hit the nail on the head - it's really a visual decision. While practicing turning in a open lot I would suggest getting out to take a look at how much room you really have between the trailer and the TV.
In my case the trailer made contact with the rear driver side of my new truck while trying to back it into a tight area. I knew it was real close and kept questioning it but my helper said otherwise and was wrong.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
