Old 03-17-2011, 09:10 AM   #1
prof_fate's Avatar
TV: Brake controller?
Just bought a TV, a 2001 expedition eddie bauer with HD tow package.
Leaning toward a reese dual cam hitch, likely this one (suggestions???)
Reese 66087 Strait-Line 800 lbs Round Bar with Shank Camper Trailer RV
From what I can gather this has the wiring for elec brakes, just need the controller that will plug in under the dash. I've never had a trailer with brakes so what is good, bad, features I'm looking for, etc?
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 03-17-2011, 11:09 AM   #2
Wanna Be Camper
SaskCampers's Avatar
We have a Tekonsha P3. IMO one of the best controllers out there.
http://www.tekonsha.com/content/prod...435&part=90195
Old 03-17-2011, 03:39 PM   #3
kz08h5's Avatar
Get a proportional type controller and not a time delay controller. Once setup the proportional controller should not have to be re-adjusted, assuming your load doesn't change. With the time delay controller you have to keep making adjustments as your speed changes. It is a pain and also dangerous. I sometimes forget to re-adjust and end up using the truck to stop the entire rig, not good in an emergency. The proportional units cost more but I think the extra money is well worth it.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
Old 03-17-2011, 03:42 PM   #4
doctort44's Avatar
We have a Prodigy and we've been very happy with it.
Terry and Joan and our empty nest
2008 Silverado Crew Cab 5.3liter 3.73
"The Cottage" (2010 Surveyor Sport 189)
doctort44 is offline   Reply With Quote
Old 03-17-2011, 03:56 PM   #5
M109Rrider's Avatar
I think you mean Inertia (like Prodigy) Proportionals are the ones that need constant adjustment. They're either on or off unless they're in a newer Ford(so I'm told) I'm told they work with the brake pedal and are truly proportional to brake pedal applied (can't confirm, just what I've been told)
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 03-18-2011, 07:07 AM   #6
Sgt. Schultz's Avatar
OP a nice write up is available at Trailer Brake Controller Information | etrailer.com - I just picked up a HUSKY Quest Proportional Brake Control ( http://www.huskytow.com/FTP/PDF/H-2-A_ELECTRICAL.pdf ) for the simple set up and the fact that it has 5 setting I can pre-set for known towing situation (rain, heavy or lighter than normal etc)
What ever brand I suggest staying away from the Ramp (time delay) type controllers.
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
Old 03-19-2011, 07:40 PM   #7
bikendan's Avatar
you can get an Equal-i-zer for less money, free shipping and no drilling needed.
also, big Prodigy fan. love my P2.
you can get both at RVW, $440 for the Equalizer and $99 for the Prodigy P2, with free shipping.
Old 03-19-2011, 07:51 PM   #8
vlt
I have a Prodigy, but don't understand how to set it. I'm going to get an Equalizer too. Is it okay to leave it attached the trailer?
vlt is offline   Reply With Quote
Old 03-19-2011, 08:09 PM   #9
bikendan's Avatar
your Prodigy should have setting instructions with it. i seem to remember that there is a starting number setting and you go from there. it's been 5 years since i first set it up, so it's a little foggy.
yes, you can leave it attached but it's not easy pulling the drawbar out of the hitch receiver. and you'll have to lock the ball to the tongue to prevent theft.
i leave mine in the receiver, with a lockable pin.
Old 03-20-2011, 02:10 AM   #10
Plug It Right
We just love Max Brake Controller. It has worked flawlessly for over 2 years. Diana
2014 Ram Dually Pickup, Tailgate Easylift, Do More Slide Step & AMP side steps
1996/2010 Triple Slide Carriage, Mor/Ryde Suspension, Kodiak Disc Brakes, Big Foot Automatic Leveling System, TST Tire Pressure Monitoring System, Plug It Right Stabilizers.http://www.plugitright.com/5thwheelREDO.html
Dutch & Di is offline   Reply With Quote
brake control, brakes
