Old 06-18-2012, 10:24 AM   #1
lowbubba's Avatar
TV brake pads
Guys,
I was wondering about brake pads for my 2007 1/2 ton Suburban. I usually use Auto Zone pads, but this was before towing. What pads have you used and liked or disliked? I need fade resistance, also good life and not a lot of brake dust.
Thanks in advance,
Randy
PS I will replace the rotors at the same time.
lowbubba is offline   Reply With Quote
Old 06-18-2012, 10:25 AM   #2
TURBS's Avatar
Raybestos premium pads!
Old 06-18-2012, 10:48 AM   #3
Glenn5995's Avatar
EBC Greenstuff 7000
Greenstuff Brake Pads 7000 Series
Glenn & Beth (Dad & Mom)
David & Audra (16 year old twins)
Glenn5995 is offline   Reply With Quote
Old 06-18-2012, 10:58 AM   #4
BigTJohn's Avatar
Cannot remember the brand, but ceramic pads seem to really work well. A bit expensive, but seem to last a long time.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 06-18-2012, 11:38 AM   #5
Wagner ThermoQuites. Almost zero dust.
Len & Cheri is offline   Reply With Quote
Old 06-18-2012, 11:38 AM   #6
Ceramic pads are great, but they will warp rotors if you ride the brakes a lot. They also have dust, even though some claim less dust, but it is white, so not as noticeable.
Also, make sure you have enough brake going to the camper. I set mine up just as if the camper wasn't there. In other words, when doing 50 mph, no camper, I notice how much pressure on the pedal, and distance needed to stop. When towing the camper, I adjust the brake controller so I use the same pedal pressure, and stop in the same distance. I feel this lets the truck use it's brakes, and the trailer use the trailer brakes. You mileage may vary.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-18-2012, 10:00 PM   #7
transamz9's Avatar
I don't use the truck brakes when towing the 5'er. I have ceramic though.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 06-18-2012, 10:36 PM   #8
Rsgtivr6's Avatar
X2, put these on my Trailblazer when I did the brakes. Very good pads.
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 06-18-2012, 10:46 PM   #9
TURBS's Avatar
Huh?
Old 06-26-2012, 06:42 AM   #10
BigTJohn's Avatar
My thought too!!?! Huh? How's that really work? Hope that was "in jest". I'm sure it was.
Brenda and John
Old 06-26-2012, 07:29 AM   #11
X3 on the Thermo Quiet pads. Used them on my last truck and Expedtion. Very little dust and little fade.
2011 F350 Lariat Ultimate Dually 6.7 w/ B&W Companion
2014 Heritage Glen 356QBQ
2016 Explorer Platinum, 1998 Mustang
1SG(Ret) (1987) US Army Aviation
Days/Nights Camped 2016: 34
dogwood36322 is offline   Reply With Quote
Old 06-26-2012, 07:40 AM   #12
trudinator's Avatar
x3. I may not know a lot about cars/trucks/brakes, etc., but even I scratched my head at this one....
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 06-26-2012, 09:03 AM   #13
transamz9's Avatar
When towing the 5'er I use the trailer brakes to do my stopping. I don't do hard stops if I can keep from it. When I have to stop hard I will then use the TV brakes. I have severe duty ceramic brake pads on my TV that put out very very little dust.
Does that explain a little better?
2006 EZ GO 6" lift
Old 06-26-2012, 10:12 AM   #14
That was my assumption when I read your post. Unless your set up is different than mine, activating the trailer brakes via your brake controller does NOT illuminate the brake lights on the TT. The brake lights will only illuminate when you step on the brake pedal of the TV. Someone please correct me if I am mistaken on this...
sdboltfan is offline   Reply With Quote
Old 06-26-2012, 10:34 AM   #15
TURBS's Avatar
That helps but that in affect is only trully prematurely wearing out your camper brakes and allowing them to overheat.
Imo its not wise but you do what you feel comfortable with.
I hope I'm never in front of you while your using your camper brakes to slow down.
Or behind you with no brake lights.
Old 06-26-2012, 10:49 AM   #16
transamz9's Avatar
Brake lights work off of the controller and the camper brakes are turned up all the way. Like I said, if I have to stop hard I will use the truck brakes. I am not a newbie at this. I believe I know what I'm doing. I'm not telling anyone that they should do what I do like most people on this board. I just made a suggestion because that is what I do and it works great for me.
To the original poster I use "severe duty ceramic" pads from Napa. No brake dust or brake fade towing 18,000# with a truck for 7 years that everyone tells me that I can't do it.
2006 EZ GO 6" lift
Old 06-26-2012, 10:49 AM   #17
^ x1
2012 Coachmen Freedom Express 292BHDS
2009 Ford F250 Super Duty CC 6.8L 4.10
Husky Centreline WDH w/Sway Control
2013 Nights Booked: 38
2013 Nights Camped: 40
pwrplay is offline   Reply With Quote
Old 06-26-2012, 10:55 AM   #18
transamz9's Avatar
Originally Posted by pwrplay View Post
^ x1
I can instantly lock my wheels on the camper and truck driving the way I do, can you?
Have you ever driven a semi? Why do you think they put a hand control for the trailer brakes in them. Control, it's all about control.
2006 EZ GO 6" lift
Old 06-26-2012, 11:07 AM   #19
TURBS's Avatar
Control with no brake lights.
And yes I've ever driven a semi ..... I am as we speak driving one .
and in 19 years of driving I've never pulled the o sh&%t lever for braking.
A semi has brake lights when lever is pulled.
Your camper/tv does not when lever is moved.
Old 06-26-2012, 11:17 AM   #20
transamz9's Avatar
Attachment 15734
I don't know why I have to explain my myself. Have ever pulled doubles? You can use you trailer brakes to help control the "wiggle". Towing for 20+ years myself. I haul 60-100,000# construction equipment now. I don't think they would allow me to do this if I were an unsafe driver.
BTW, how can anyone that has not seen my set-up tell me that my brake lights don't illuminate when I use my brake controller?
2006 EZ GO 6" lift
brakes
